Quote: Originally Posted by
VettePC
How did you wire up the power? Which pins on DIN connector? What source of +12V are you using? If you have a digital Volt meter check to make sure the 2 pins are getting a solid +12Volts.
I need to find the correct connector to fit into this radio! If you find it let me know.
i just made a cable for my project and it worked lie a champ
note set com port to hardware control and turned down the recive buffer to help debug
check out ihacked site or pm me and i will get you the schem.
