Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Old 11-13-2008, 08:15 PM   #31
frozenbinary is an unknown quantity at this point
i have an xm radio working with its antenna in the same spot as my car - pc xm direct antenna... what am i doing wrong ?
frozenbinary is offline   Reply With Quote
Old 02-16-2009, 01:59 PM   #32
navputer's Avatar
navputer is an unknown quantity at this point
**Bump**
Is anyone experiencing a problem with their XMD1000 unit? I have this connected to MP3Car USB Adapter and here later, I have to unplug for a few seconds and plug it back up to get power. The usb adaper is powered by my M2ATX (originally M1ATX - same issue). It was working fine for some time but all of sudden it has been happening for the last few weeks.
When it does power up, it works fine but when I go to use it again in RR, of course, the XM screen does not come up.
Is my XMD1000 bad or problem with USB adapter? I see the USB adapter in device manager (no issues) and I also uninstall and reinstalled the drivers but same thing occurs.
Gee
navputer is offline   Reply With Quote
Old 02-23-2009, 10:06 PM   #33
insaneramman's Avatar
insaneramman is an unknown quantity at this point
Question 12v direct?
Use your battery power. See if that works, I ran mine with no problems straight off my battery.
For those who fought FREEDOM has a flavor the PROTECTED will never know. Support our troops.
insaneramman is offline   Reply With Quote
Old 11-05-2009, 12:08 PM   #34
IssaquahWA1979's Avatar
IssaquahWA1979 is an unknown quantity at this point
So I am thinking about taking my XM Direct and adding it to the system. So are you guys powering the unit on/off with both pins all the time? That may be why some are having issues if the direct receiver looses main power then it looses everything in memory such as last channel etc. So when I had mine hardwired into my truck (since it was said you could not have XMD with U-Connect) if I used the ignition on/off it would remember everything like presets etc. but if I pulled the battery or something like that it would loose that info. Just a thought on why some are having stability issues?
Shuttle Tear down AMD 1.67g, 2gb RAM, Creative Sound Blaster Audigy. Elios 15" TS monitor on custom mount.
System installed into 2005 Dodge Ram 3500 Cummins Diesel 4x4.
IssaquahWA1979 is offline   Reply With Quote
FAQ: Installing XM Radio on Your Carputer, a Tutorial Bugbyte The FAQ Emporium 8 03-14-2008 01:36 AM
XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer Will Albers General MP3Car Discussion 2 03-27-2006 09:49 PM
XM Test Program Viscouse General Hardware Discussion 5 08-28-2005 05:15 PM
XM Test Program Viscouse Newbie 0 08-23-2005 08:48 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
