Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
View Poll Results: What is the best GPS Receiver?
BU-303 22 8.21%
BU-353/355 137 51.12%
Holux GR-213 37 13.81%
Holux GR-212 8 2.99%
Royaltek Sapphire 1 0.37%
Garmin unit (post your model!) 14 5.22%
Ublox unit (post your setup!) 2 0.75%
Bluetooth unit (post your model!) 9 3.36%
OEM unit (post your setup!) 12 4.48%
Other (post your setup!) 34 12.69%
Multiple Choice Poll. Voters: 268. You may not vote on this poll
Old 07-02-2006, 12:32 AM   #16
Registered User
nadir_s's Avatar
nadir_s is an unknown quantity at this point
i dunno about "best" ... because to make that judgment, you would have tried the other products listed as well.
Probably the one you've had good experience with is a better choice ... but anyways, I voted. BU-303, though cheap, has worked well for me!
[ 5-spd 1996 M A X i M A SE ]
nadir_s is offline   Reply With Quote
Old 07-02-2006, 01:01 AM   #17
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
how did you forget to put the Rikaline 6010 in your poll????
btw, that's what I use.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 07-02-2006, 04:36 AM   #18
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
Ummmm... were the hell is Earthmate
I voted other.
0l33l is offline   Reply With Quote
Old 07-02-2006, 05:14 AM   #19
Gearhead61 is on a distinguished road
The one I saw/heard most about was the BU-353, so that's the one I've got.
Gearhead61 is offline   Reply With Quote
Old 07-02-2006, 08:30 AM   #20
Uriel's Avatar
Uriel is on a distinguished road
I have the BU-353 and it's great!! I've been using it now for about 10 months and never had any problems with it. during driving up to 12 satalites!!!
Normally up to 7-8 satalites.
www.carputershop.nl for all your carputerstuff!!
Uriel is offline   Reply With Quote
Old 07-02-2006, 09:36 AM   #21
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
I voted other.
because there's a 10 item limit.
Quote: Originally Posted by DarquePervert
If there are other GPS units you feel should be added to the list, I can't. The poll is limited to ten entries. However, please choose OTHER and post your setup so newbies can see what options are available!
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 07-02-2006, 11:00 AM   #22
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
From my experience, it is not waterproof.. water-resistant perhaps, but after opening it up to repair a cut cable and seeing the components rusting away, definitely not waterPROOF.
My experience with this Earthmate has been good.. If you put it in a location where it has a decent view of the sky and can get a decent lock. Mine was mounted on the inside of my fiberglass trunk lid. Lack of magnet mount and the detachable USB cable limit your mounting options the vehicle's interior.
BU35x/SirfSTAR III.. definitely the best way to go at this point.. great chipset. Mine works inside the passenger compartment where the Earthmate failed.
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 07-02-2006, 11:37 PM   #23
My Village Called
0l33l's Avatar
Well... then maybe the BUs and the Holux should been combined.
Old 07-03-2006, 07:41 AM   #24
_
if they were, someone would come in and complain about that...
Jan Bennett
Old 07-03-2006, 02:47 PM   #25
My Village Called
0l33l's Avatar
So true
Old 07-27-2006, 09:38 PM   #26
Raw Wave
shotgunefx's Avatar
shotgunefx is on a distinguished road
Just got my Holux 213, works great. Plugged it in and got 11-12 satellites indoors almost immediately.
Even more impressive is I live tucked between two big banks, I can barely get FM/AM or TV reception in here. Lot's of shielding, lot's of noise.
The only issue I have is that at first, I had problems accessing it or if I did, I'd get read errors. It turns out that there must be something buggy with the PL2303 drivers for linux. I have another PL2303 serial converter on the machine too. It recognized both correctly, but it won't work with both plugged in.
Strange.
shotgunefx is offline   Reply With Quote
Old 07-28-2006, 08:48 AM   #27
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
bu353. mounted on my roof and never ever have any problems with it connecting or sat counts.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 08-13-2006, 10:50 AM   #28
cheshireccat is an unknown quantity at this point
Vote other!!
Well, I looked at all the available USB GPS units like the ones on the list of choices, but I didn't want the cable coming out the side of it. Impossible to mount it externally and have it look good (with no wires going around). Well, I have a 1967 mustang that I am installing all this in and I want it to look stock from the outside and from the inside (mostly). I was wondering how I could minimize the impact and the eep the good looks. I finally, after months of searching (actually a couple hours on the internet), I have found what I need. I have been planning on removing my antenna from the outside of the car and hiding it on the inside of the windshield, so I was going to have to fill in the hole it is currently mounted in, and repaint the whole panel as this would be a big hole to fill. Then when I found this GPS unit, I knew that I could just use the old antenna hole. I have not tested it yet, but I do have one here. It's waterproof, It will be sealed against the body in the old antenna hole with silicone and locked in place with a locking ring with the nut and the silicone will adhere pretty well. And it comes with a 15' cable to go through the firewall, under the carpet and under the passenger's seat. This is the best option I have found and know that a lot of you will be taking my idea, thus the long post before I tell you which one. The US Global Sat MR-350 WAAS Enabled Water Proof GPS Receiver. I am including two pictures, one of the unit, pretty cool and one of the design specs.
picture of it
<img src="http://i31.photobucket.com/albums/c355/cheshireccat/MR-350_.jpg" border="0" alt="goto http://i31.photobucket.com/albums/c355/cheshireccat/MR-350_.jpg">
and the specs:
<img src="http://i31.photobucket.com/albums/c355/cheshireccat/MR350_specs.jpg" border="0" alt="Goto http://i31.photobucket.com/albums/c355/cheshireccat/MR350_specs.jpg">
Now that you have seen it, what do you think? pretty good option, just drill a hole and you run the cable and done...
Last edited by cheshireccat; 08-13-2006 at 10:53 AM. Reason: poor spelling, stickler for grammer.. lol
cheshireccat is offline   Reply With Quote
Old 08-16-2006, 11:03 PM   #29
gregas is an unknown quantity at this point
Garmin 15L
Garmin 15L: Small, cheap, works
Hirschmann GPS, WiFi, GSM rooftop antenna: High geek factor
See below, it's in the lower right of the top plate. This brick fits inside an ampie case.
gregas is offline   Reply With Quote
Old 08-16-2006, 11:58 PM   #30
Cheekz185 will become famous soon enough
I use a Holux GPSlim 236, great reciever!
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Question on Garmin 16 GPS receiver cproaudio GPS 19 05-23-2008 02:32 AM
Proper Installation of GPS Receiver ummagawd GPS 5 04-22-2005 12:07 PM
GPS poll maxxell GPS 14 03-25-2005 01:33 AM
How do I setup my GPS Application ? guino RR FAQ 0 03-20-2005 03:17 PM
what to look for in a GPS receiver? doublestack GPS 7 10-01-2004 04:05 PM
