Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Old 06-19-2006, 02:27 PM   #1
Will Albers is on a distinguished road
FAQ FAQ: Tools you must have to troubleshoot.
Please add other tools as desired...
I'm not claiming to be an expert on the matter, but i do have over 10 years of experience in A/V troubleshooting/Installation/repairs/sales. The most stimulating has to be the troubleshooting. Its a puzzle with scientific reasoning behind the system. Its a beautiful thing when you can locate and isolate an issue, fix it yourself and then help your friends when it pops up again.
I have weened off of it in the past few years as my career has moved towards Geographic Information Systems and less A/V but there are still a handful of tools that i will never, ever be rid of...
First off: The multimeter...
You MUST go out to Radioshack and buy a multimeter. They come in many sizes, shapes and price ranges. I recommend digital, somewhere between $50 and $100. Its up to you how much you want to spend but I have had mine for 10 years - through rain and snow. It is the backbone of every good troubleshooter. It will allow you to test voltage at components (is there really 12v at the amplifier? is the remote turn on working?). It will test the impedence of speakers to see if they are blown. It can check for good grounds and shorts. It can even check current to see how much your system is drawing. Its the brains of the opperations and a must have. If you are coming at this forum with a troubleshooting question, I will assume you have already taken the first step and purchased a multimeter
Secondly: Crimpers...
My god, I have had my crimpers at my side for all 10 years. You will use them to cut and strip wiring. The imaginative things I have done with them is beyond belief... I have bent steel, unscrewed bolts, cut carpet and even crimped once or twice. They are cheap and effective. They come in two styles and I recommend the kind pictured in the second picture but thats only after you have some experience with them.
Third: Speaker popper...
This is so simple and such a great tool. Grab an old used 9v battery and solder on a piece of speaker wire. One wire to the plus, one to the minus. Make the speaker wires about 12 inches long and make sure one of the two wires is significantly smaller than the other so they cant easily short. You will use this when you are trying to tap into factory wiring or decipher factory wire codes. Look at it this way... you have 16 wires in a factory loom. You know that 4 pair go to speakers... You have used your multimeter and found pairs that equal 4 ohms. You may have found 5 or 6 pair that equal around 4 ohms. So which pair goes to which speaker? Hook up one of the leads on the speaker popper to one wire and quickly tap the other wires together. You will hear a pop. That will tell you which speaker's leads you are holding. Run that around all your pairs and you now know which is which.
Just dont hold the wires together... you want to quickly scrape the lead like you have seen on movies where people hot wire cars.
Fourth: Snap-on rathceting screwdriver with tons of bits...
This is pretty self-explanatory but I have had mine (minus the bits) for over a decade. It has never let me down. Grab one and love it.
Fifth: Shorting plugs
Shorting plugs area pair of RCA ends that have had the inner and outer wires soldered together. These are used to test an amplifier. If you have some sort of issue with an amp (noise, popping, etc), remove the RCAs and plug in your shorting plugs. If its still doing it then you know its either the amp, or something from the amp out to the speakers. Amplifiers require a signal to turn on the output. Shorting plugs "turn on" the output while eliminating the actual signal (which may be the issue in the first place). They are a quick and easy way for you to determine if the problem is before, after or in the amp. Search for "shorting plugs" for more information
I will come up with a troubleshooting handy guide in a bit but please add on new tools that you think are a MUST have. I know guys and their tools, so please dont list everything out there. Im more interested in the top 5 tools you could not live without.
Will Albers is offline   Reply With Quote
Advertisement Sponsored links
Old 06-19-2006, 02:35 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
kudos on a good post
have you thought about writing a troubleshooting post about how to trouble shoot system noise? would be quite helpful for others around here.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 06-19-2006, 02:36 PM   #3
Sure, I had about 10 mins to kill while waiting. I was going to send that to you for your post but saw it was locked. Feel free to add it on if you like.
I will write up a lil guide on noise reduction when i have a few.
Old 06-19-2006, 02:44 PM   #4
_
that would be sweet! might be able to get it to be a sticky too!
maybe add it on to this one and see if DP would make it a sticky for this forum?
Jan Bennett
Old 06-19-2006, 02:48 PM   #5
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Stickied.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 06-19-2006, 04:17 PM   #6
_
Sweet!
Jan Bennett
Old 07-10-2006, 08:12 PM   #7
adaminc is on a distinguished road
Hmmm, tool I can live without...
A good set of wire strippers, I know a lot of people that use knives etc.., but I prefer a good set of wire strippers so I dont damage the wire. I also use my soldering iron a lot, with some good lead-free silver solder!
Hey Laserlips, your momma was a snowblower!!
adaminc is offline   Reply With Quote
Old 07-11-2006, 11:38 AM   #8
pancit175 is on a distinguished road
Knives, ha, I've seen some ghetto *** people use their teeth to strip the wires.
PROGRESS:
pancit175 is offline   Reply With Quote
Old 07-11-2006, 12:03 PM   #9
Takes it in the Rear
kevinlekiller's Avatar
kevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud of
kevinlekiller is offline   Reply With Quote
Old 07-11-2006, 12:18 PM   #10
FC3S's Avatar
FC3S can only hope to improve
i've never done that
FC3S is offline   Reply With Quote
Old 08-17-2006, 05:53 PM   #11
Killa200 is an unknown quantity at this point
My top 5:
Multimeter: god at the shoddy wire runs i would have went insane over if i didn't have one to test things out with. Such an invaluable tool not only in the car but aroudn the house.
Wire Cutters: keep a few various sets around with me, a few snub nosed with long handle for the 8 - 2 gauges, and a normal pair like Will had in the 2nd pic for the smaller gauges. Also carry a small razor blade to cut insulation on the big gauges.
Soldering iron: Not just for soldering! Sometimes you get that client whose old dash plate was just a wee bit sun warped, and theres no way in gods name i am bending that fragile plastic without having a little give in it, Great for the heatshrink for your splices after your done soldering thing up... and the occasional time where somehow, you've misplaced those wire cutters,
Assortment of bits and hand tools: Sure wire cutters are hand tools, but with as many as they make, and as valuable as they are, they get a cat of their own. My kit has suck things like: torx bits, star bits (with saftey punch) 90 degree screw drivers (for those tight spaces), sockets and drivers, as well as the usual screw drivers. When you start messing with all the manufacturers various ways of doing things, your learn quick that they can be screwey with things.
Cleanups: Split loom, zip ties, fasteners, and the likes. When i get done i want my install to look like it rolled off the line that way. No shortcuts. It may have taken an extra 30 minuites to fish the wire in that manner and fasten it under the dash.. but did you know it was there till i told you? Didn't think so,
Killa200 is offline   Reply With Quote
Old 08-17-2006, 06:00 PM   #12
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Wiredwrx has a little shameless behaviour in the past
I would add that if possible, the multimeter should be able to measure at least 10 amps, and preferably more, though they tend to get expensive when they can measure that much amperage. If not, you can buy a Panel Mount Amp Meter (from someplace like www.allelectronics.com) for about 15 or 20 bucks, and just use that.
Also, a lighter. You use the lighter to shrink heat shrink tubing, though there are better or other ways, a lighter is pretty easy, cheap, and easily replacable.
A small socket wrench, with extensions. You may not need a bunch of sizes, since 10mm seems to be a very common size that one works with on a car, I would get at least a set with 14 mm being the biggest, going down to at least 4 or 6 mm.
My .02,
Michael
Wiredwrx is offline   Reply With Quote
Old 08-20-2006, 12:38 PM   #13
Ces///M3
I would add to this list,
a nice tone/probe generator, this tool helps with tracing wires in a bundle, great underneath the dash, as well as in home theater, where its a godsend.
and probably the best tool radioshack sells, a small butane soldering iron
this guy is cheap, works great especially stuck underneath a dash, best 20 bucks I ever spent.
Ces///M3 is offline   Reply With Quote
Old 11-16-2006, 12:25 PM   #14
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
Pick tool for getting panels off or all sorts of things.
Battery for checking speakers/polarity and other uses that I can't remember for now. Just make sure you know they are speakers wires before hand with a DMM by checking for resistance first. Otherwise see next post.
Here is a good example. You have a factory amp you just removed. You want to use the speaker wires and you have located the speaker wires via testing with DMM. Then you can use a standard battery to check which speaker wires go to each speaker by essential "popping" it with the battery.
System always under construction
durwood is offline   Reply With Quote
Old 12-07-2006, 10:53 PM   #15
nserpa9248 is an unknown quantity at this point
power probes are a really bad idea in the hands of an untrained installer / diy'er.
I know of too many airbags set off by power probing the wrong wire.
Testing a wire for OHMS is usually a good way to see if its your wire first (2,4,8 are all numbers you should see pop up), then using a power probe on those wires to see which ones would be a good idea, just test first...
nserpa9248 is offline   Reply With Quote
FAQ: XM Cable/XMD1000 Debugging FAQ (test program included) pyros The FAQ Emporium 33 11-05-2009 12:08 PM
Skin making FAQ? Caelric FP Skins 4 12-19-2006 02:31 PM
FAQ: Tools you must have to troubleshoot. Will Albers The FAQ Emporium 11 09-29-2006 01:15 PM
FAQ: Attention Newbies! The quickest way to learn about Car PC's Bugbyte The FAQ Emporium 2 06-19-2005 04:18 AM
n00b looking to get some tools souljetta General MP3Car Discussion 16 01-01-2004 05:00 PM
