07-05-2006, 12:29 AM
#1
Possible FAQ for audio(need help)
NOTICE: This is NOT to be used as a source of information until this notice has been removed! It will be removed when I'm reasonably sure the information is accurate enough to help people!
Below is what Ive started, can somebody help with this, and correct any errors, and possibly post it as a sticky? Thanks! I think it would help!
This is my attempt at car audio FAQ.
It is my hope that this article/post teach you:
1) What different stereo components do
2) Options to look for in said hardware.(I need help with this)
3) Options for replacing a head unit(will do later)
If there are any errors please let me know so i may fix them!
Section 1: Stereo components and what they do.
This section will explain the following components:
Headunit Or Deck
Speakers
Equalizers
Crossovers
Amplifiers
Stiffening Capacitors
Special thanks to:
Red GTi VR6
DJiK
For helping make this accurate, and possible.
Headunit or Deck
Deck or Headunit, We all have seen one but do you really know what it does? I know I know it plays music. But what we really need to know is all the components that make up a head unit. For example did you know that most headunits include an amplifier built-in? Sure its not the strongest or most powerful one, But had it not amplified the signal chances are you wouldn't hear it.
Many of the after market HU's come with an auxiliary input. This means that the basic CarPC could be plugged in to the car's audio system by a single stereo wire.
What to look for
Well, if your going to use your headunit with your carpc, you probibly want an auxiliary input in the rear of the unit. This way the wires arn't hanging everywhere, and you don't need to use an unreliable FM transmitter. If your unable to purchase a new or used headunit with auxiliary input, a FM transmitter will work, if properly positioned (I personally used a belkin, when i didn't have a cd player). Typically an FM transmitter is meadicore at best, and should be considers a last option resort only!
Any other suggestions for this??
Equalizer
Most Headunits have an equalizer built in. There are also many many external models. Some are primitive, such as an adjustments for bass or treble. Some are more advanced, similar to that in winamp or similar programs that include multi-band adjustments. (Bands are selections of a signal, just like your favorite radio station is a small selection (200hz) of the FM band). The equalizer is particularly useful for fine tuning a setup.
Many people including myself mess with the settings because it just sounds 'better', or maybe were bored. Theres nothing wrong with this either, Its just about personal preference.
What to look for
As with everything theres several different opinions. Theres 1/2 DIN, which is just its size, there are also full DIN size models available. Personally I'd suggest the 1/2 DIN as it takes up half as much room as most stereos. However kits for the install of the full DIN sized models are much easier to find.
The 1/3 octabe 31 band EQs that are HIGHLY saught after by those in the quest for supreme SQ from the audio systems. These EQs FAR surpass WinAmps capabilities.
Another option you may be interested in is fader or fade control, This is what allows you to put more power to the front speakers then the back, or vise versa. Tuned correctly this dosn't generally need to move. However if you have sleeping people in the back it may be nice of the driver to turn the back speakers down or off using the fade control. This way its a little louder to the front passengers, while not likely to wake the other passengers.
A lot of the models Ive seen also have a master volume control, which is of course a technical name for the volume control. This is good when or if you want an easy and tactile way to adjust the volume. Which is something I personally prefer.
Crossover
Then theres the crossover, This can also be built into some Headunits. It limits what frequency's a certain channel gets. Think of it like this, Most of the time you don't have particularly large speakers up front. Their better for playing highs or treble, whereas your back speakers are generally bigger. They're more apt to play bass or low frequency. The lower the signal the more the speaker has to move, Typically speaking the larger speakers have more room to move, and because their larger they don't have much trouble being so loud. So basically up to a point its less strain on the speaker to provide a lower signal (like bass) at a higher volume. So in short you would probably take the higher signals (treble) and put them to the front, meanwhile not letting it play lower frequency's. Then your back speakers can play the midrange, without worrying about the highs, or the lows because other speakers are taking care of those. This allows it to play clearer without so much stress and distortion. And your subs are playing all the bass, but not anything above the midrange. This allows for all of your speakers to play their strengths, while not making them play the entire audio range at the same time.
Some speakers (like those three ways or two ways) claim to be able to do that, However in my personal experience, they don't work all that great, but they're better then nothing.
What to look for
Theres two basic kinds of crossovers that I've seen. One type only allows a certain frequency to pass through the line, to one speaker. You would need to buy one for each speaker you have. The other is like a control board, this type is usually adjustable. One think you need to make sure of with the later style is that you get a stereo not mono, as you have a stereo (IE: atleast one left and one right speakers) the second thing is you need to figure out how many channels there are. Most amplifiers have a crossover built in (as far as Ive seen) So chances are you dont need an external unit. However if you do make sure you have enough channels Usually 6 (2 front speakers,2 back speakers,2 subs)
Amplifier
Now onto Amplifiers, I don't want to start a debate here. And there are many many better places to find information on these, However, They are quite simple as far as what they do. They take a signal in, and put out a stronger signal! This usually equates to louder volume, or stronger transmitted signal and therefore in both cases better range (the louder a cd is playing, the further away from it you can hear it, same with a transmitter, the stronger it is, more or less, the better range it has. (not quite true but for just audio principals I'm not going there....)
This site is very informative, and so until somebody helps me, this is what its going to be for now: Click me
Somebody else is more then welcome to write for this section!
What to look for
Use only the RMS numbers!
Find out what your speakers are rated in RMS Watts, and make sure your amplifier is that or less. However it can be a good idea to purchase a more powerful amplifier then you need, and turn it to a lower setting as its not going to generate as much heat vs the heat it was designed to handle. For example a 1000 watt RMS amp, turned to half, is only going to use half the power. So it will only loose half as much through heat as normal (more or less). Meaning the amplifier should stay cooler, and therefore less stressed.
Carputer Status: 10%
Have: Dell L400 (700Mhz 32?RAM, 20Gig HD), 7" Newvision, Pioneer DVDRW/CDRW via USB
Need: Amp.
07-05-2006, 01:02 AM
#2
_
kudos!
might I suggest that you add in some formatting?
Some bolding and enlarging of text to distinguish the different segments? Some underlining to emphasize things?
Just a thought to help make it more readable!
btw, I haven't read any of it yet, just scrolled through and noticed this. I'll make it a priority to read tomorrow though!
07-05-2006, 03:10 AM
#3
Since this isn't a Wiki-like thread, I can't really edit the things you had said and the minor spelling mistakes you've made. Instead, I'll write what I'd want you to consider/add below, and later delete my post.
Headunit:
Many (if not all) of the aftermarket HU's come with an auxiliary input. This means that the basic CarPC could be plugged in to the car's audio system by a single stereo wire.
BTW, "we all have one [deck]" is a misleading statement because I, for instance, haven't had one in the car for about a year now.
EQ:
External equalizers also exist -- that is, outside the HU.
If anyone decides to use one of those, primitively speaking they can wire theis setup in the following order:
CarPC --> EQ --> Amp
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
07-05-2006, 05:31 AM
#4
Youl be happy to know I'm going back to school.
Sad thing is Im not kidding.
Need: Amp.
07-05-2006, 05:44 AM
#5
Assuming you were going to connect EVERYTHING, would it be like this?
Source (car pc) > EQ > Crossover > AMP > speakers?
The only thing im not sure of is the EQ and crossover (which order would be best? i assume putting the amp after the speakers may be a bad idea, so :P
Need: Amp.
07-05-2006, 06:35 AM
#6
fairly sure I've fixed most spelling erros (I didnt use spell check before)
Anybody know of anything else that needs to be on this?
I figured if i started it, people would help me make it complete (and thus help me, and everybody else in the process
Need: Amp.
07-05-2006, 07:44 AM
#7
_
Quote: Originally Posted by DJiK
Headunit:
Just being nit-picky here. Many is correct, all is far from correct. More and more are starting to have them though.
Now onto the rest of the thread!
07-05-2006, 07:48 AM
#8
Ok Thats been fixed. Ild prefer everybody nit-pick. Leaving this to be correct and helpful vs not being so much helpful.
So Thanks for your help
Need: Amp.
07-05-2006, 11:08 AM
#9
_
Quote: Originally Posted by Simy
For example did you know that all headunits in your car include an amplifier?
This is not true actually. Many of the high end HUs do not have internal power. This is actually HIGHLY desired in the high end relm by many audiophiles. Though these HUs are becoming less and less common due to consumers driving the market.
You might want to at least make a mention that many times this will lead to the worst sound quality out of all options. FM transmitters are known for being extremely noisy. Some instances show this to not be the case, but those are by far the minority. I would just hate for someone to go into one of these thinking it will be JUST as good if not better than other options.
If you wanted to go into more detial, you can mention the 1/3 octabe 31 band EQs that are HIGHLY saught after by those in the quest for supreme SQ from the audio systems. These EQs FAR surpass WinAmps capabilities.
Quote:
(Bands are selections of a signal, just like your favorite radio station is a small selection (200hz) of the FM band). The equalizer is particularly useful when your used to hearing more or less bass, for example. Lets say you go from country to rap, and you had it tuned so the lower pitch in the country songs are a little louder by turning the bass up, or its corresponding frequency, then you listen to rap, you had the treble low, because you didn't want the 'twang' of the country to be so deafening, but on your favorite rap song thats all wrong! because the higher pitch is too loud and the bass isn't quite loud enough, or is too loud as well. Now while there are systems which don't have adjustments there usually level. Think of it as being neutral. There not to loud or too quiet. Each frequency depends soly on what the audio source says it should be. This is fine or some people and theres really no problem with it. However allot of people including myself mess with the settings because it just sounds 'better'. Theres nothing wrong with this either, Its just about personal preference.
I just take a bit of issue with this part. See, a properly tuned and installed system shouldn't fall into any of these problems. But, we all know, that most people don't spend the time to properly tune or install components in their ideal locations. So I can see this making sense to those people. Maybe a disclaimer that a properly tuned system wouldn't have these problems? Up to you.
full din units might be easier to install due to kits being more readily available.
Just a quick grammar fix.
quick fix.
07-06-2006, 04:51 AM
#10
I've changed it a little for now.
If you know what should be put there, or along the lines of what belongs there, ild love your suggestions.
I have a feeling you could have written this in under 5 minutes.
Again, Thanks for your help.
Need: Amp.
07-06-2006, 07:39 AM
#11
_
hehe - I like seeing other people write this stuff up. The thought hadn't crossed my mind for something like this honestly. It's all basic knowledge for me and many others that we just tend to take for granted, unfortunately.
It's because of people like you that these threads get started in the first place! And that's a good thing!
07-06-2006, 08:50 AM
#12
I know whatchya mean, My friend gives me a confounded look anytime i say anything about do anything with my car. But he still wants to help me do the interior. I cant wait for my screen to get here, lol auction ends today, i still havnt won... just yet.
Im SOOOO excited.
As far as the audio goes, Could you give me some pointers on the best way, and the least workably espensive way to bypass the headunit?
For example, apparently i was wrong about what components do (big supprise there, lol) so what do you really need for a good sounding system? apparently from what ive learned with some threads a headunit should act as a crossover, and an EQ, andd most amplify the signal, so do you really need all those components?
Not to mention if this is to sound BEST without breaking the bank (ild say $400-$600 is ok for good parts, not including speakers) what would you want to look for?
and if you were just going to replace it el cheapo style, wouldnt a good 4 channel amp work? (then you could adjust its fade and balance through the amp (im assuming here)
Thanks again for your input
Need: Amp.
07-06-2006, 09:26 PM
#13
If by "least expensive" you mean with as few accessories that one has to buy, then in my opinion it'd be this:Source (CarPC/iPod/CD Player/$1 FM Radio) --> Amp (1/2/4/5/6 Ch.) --> Speakers (Subwoofers/Components/Tweeters/etc.)
Battery --> Fuse --> Amp(+)
Amp(-) --> Ground on the chassis
Acc. wire (tap to it at the former HU location, power antenna, etc.) --> Amp(remote) Extra things like:Wire lengths, sizes ,and types, adapters, connectors, and labor all vary from one setup to the next.
If anyone knows of a more basic "diagram" than what I described, please post here.
07-07-2006, 12:04 AM
#14
Its funny with this entire thread, everytime i check on mp3car, Sombodys always posted here at almost the exact same time....
And thanks for your input!
I'm assuming a more advanced all features type setup would include an EQ or possibly a crossover, and thats mainly the diffrence (besides quality of components)?
Need: Amp.
| Thread Tools |
| Display Modes |
Linear Mode
