Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Old 05-10-2006, 02:33 PM   #1
3g Jester's Avatar
3g Jester is on a distinguished road
FAQ: Proper Cable and Power Wire Sizes
http://www.the12volt.com/wiring/recwirsz.asp
3g Jester is offline   Reply With Quote
Old 05-10-2006, 10:45 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Thanks to 3g, we have a link to a very frequently asked question: "What is the proper gauge for the power wires for my PC installation?"
Of course, this is dependent upon your installation. How much power does it draw and how far are you running the cables? The link above provides a handy reference for using the proper gauge of wiring.
Why is it important to have the proper wire size? I mean, after all, aren't we just talking about 12 volts here? We are. We're also talking about your car catching on fire from an electrical overload if you use wires that aren't sized for the load.
Say that with me again: F-I-R-E. In your C-A-R.
I've said it in previous postings on installing a PC in your car, but it bears repeating again; the supply of power to your PC is the most critical portion of your installation. Improper cabling, grounding, or power supply will at best cause your PC to crash unpredictably and at worst cause a fire.
You have been warned. Thanks 3g! Thread title changed to FAQ format and added to the FAQ to the FAQ's.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 05-16-2006, 09:26 AM   #3
3g Jester's Avatar
mmm may i add that always make sure you have the proper fuse right after your battery for maximum saftey if you running wires into the interior of your car, under carpet and such.
Old 07-19-2006, 05:58 PM   #4
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
FAQ FAQ: Determining proper gauge wire/fuse size/battery size/alternator size
This has proven to be very helpful for some individuals, just thought I would start a new thread with the hopes that it could be stickied for quick and easy reference.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 07-19-2006, 07:57 PM   #5
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Actually, moving it to the FAQ Emporium is an even better solution.
Excellent find...
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
