Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Old 05-10-2009, 01:36 AM   #46
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
DO you have the motherboard switch hooked up?
blk02si is offline   Reply With Quote
Old 05-10-2009, 06:56 AM   #47
Cyberphox's Avatar
Cyberphox
and do you have the pins on the motherboard power connector jumpered?
Cyberphox is offline   Reply With Quote
Old 05-10-2009, 12:03 PM   #48
jpinkerton's Avatar
jpinkerton is on a distinguished road
With only 15Amp on the 12V that's my problem.
The PSU in my desktop PC has 52amp on the 12V. I'm going to rip that one out of there and see if it works.
jpinkerton is offline   Reply With Quote
Old 05-11-2009, 12:52 PM   #49
SLIVER23 is an unknown quantity at this point
Another Method
For those that can't get this to work and wanted another quick check for their power supply. I successfully booted my M4-ATX and computer using a cordless drill battery (18V). It keeps my computer running for 20-30 mins before the M4 soft shuts the computer down (voltage gets low). Obviously test the leads on your own battery but on my Dewalt the rear lead is negative and the front is positive.
Battery reads around 20v without any load from it and about 14 when the M4 is powered.
SLIVER23 is offline   Reply With Quote
Old 06-26-2009, 06:13 PM   #50
focus_se is an unknown quantity at this point
I am using a 24 pin atx psu for my workbench. I found some pinouts online but I dont think they were the same, so Ive had to leave it plugged into another mobo.
Anyone out there know the pins needed to "jumpstart" the psu?
focus_se is offline   Reply With Quote
Old 06-27-2009, 11:44 PM   #51
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
A 24pin is exactly the same as a 20pin + a 4pin extension. Most good quality and up actually have the 4pin extension detachable.
So it is still pin 14 shorted to ground.
Old 06-28-2009, 01:12 AM   #52
High Voltage
blk02si's Avatar
Green Wire shorted to ground
Old 08-04-2009, 05:58 PM   #53
Wagonmaster's Avatar
Wagonmaster is an unknown quantity at this point
I have a Radio Shack power supply that will give me 13.8 volts and 3 amps.
Is 3 amps enough?
Russ
'93 Caprice Classic "Woody"
SP13000
TM-868
Streetdeck
XM PCR, Usb Radio, WIFI, GPS, PCTV HD
Wagonmaster is offline   Reply With Quote
Old 08-04-2009, 06:04 PM   #54
2k1Toaster's Avatar
Is 3 amps enough?
3A * 13.8V = 41.4W [Watts] at 100% efficiency. Usually those are 85% to 75% efficient, so you really have 31W.
So if you are running less than 31W worth of stuff, you should be ok. Otherwise, no.
Old 08-04-2009, 10:11 PM   #55
Thanks Toast-Man
Russ
SP13000
TM-868
Streetdeck
FAQ: How to Wire an OPUS PSU Quattro The FAQ Emporium 74 08-26-2006 01:38 PM
Is it Necessary to have a Power Regulator Connected to the PSU? lfilomeno Power Supplies 5 07-22-2005 01:59 AM
Power USB hub from psu meyer64 Power Supplies 13 03-20-2005 11:34 PM
Need help finding an AC to DC power adaptor Squeezer General Hardware Discussion 3 12-29-2000 01:27 PM
dc to dc ATX power supply Kaizer Soze General Hardware Discussion 10 10-21-1999 08:47 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
