Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Old 10-04-2006, 06:41 PM   #1
v8 scimitar's Avatar
v8 scimitar is on a distinguished road
FAQ:Resuming from Hibernation; A beginners guide to Devcon
Windows not resuming from hibernation properly? Well this might be an answer for you. There is a utility from Micro$oft called Devcon that can disable and enable devises for you that should help sort the mess. Trouble is it isn't very user friendly and seeing lots of people struggling with it over on another thread I decided to do this tutorial. So grab your copy here and see if it helps you out. It is written for the complete beginner so goes through the absolute basics.
It isn't a guaranteed fix but if windows wont come out of hibernation or some USB devices don't work properly when it does then this is well worth a go.
Usual applies have a read through it first before you start messing about and if you still don't understand it then leave it alone as I am not going to be responsible if you break your machine, although it's unlikely.
Any questions, ask away and I will see if I can help you out.
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 3 years installed and it just keeps running!
v8 scimitar is offline   Reply With Quote
Old 10-05-2006, 06:17 AM   #2
rcdash's Avatar
rcdash is on a distinguished road
Very nicely done. Thank you.
rcdash is offline   Reply With Quote
Old 10-12-2006, 12:29 AM   #3
JonDubya is an unknown quantity at this point
Thanks for the write up! This has fixed my GPS locking issues.
JonDubya is offline   Reply With Quote
Old 10-12-2006, 07:49 AM   #4
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a name known to allBugbyte is a name known to allBugbyte is a name known to allBugbyte is a name known to allBugbyte is a name known to allBugbyte is a name known to all
Thanks for this. Edited title to include terms "resume from hibernation"
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 10-12-2006, 11:04 AM   #5
Glad it helped you out jonDubya.
No problem Bugbyte good thinking.
Old 10-16-2006, 09:19 AM   #6
toberdorf is an unknown quantity at this point
Will these fixes work when running windows on a Mac Mini running boot camp? I understand that there are a lot of problems with waking up windows after its been to sleep. Thanks for your help.
toberdorf is offline   Reply With Quote
Old 02-01-2007, 06:20 PM   #7
hari-bhari can only hope to improve
worked like a charm, thanks! i just disabled and enabled my entire usb hub, so everything connected to it started working fine.
hari-bhari is offline   Reply With Quote
Old 02-12-2007, 10:43 PM   #8
here's a neat question:
two of my devices (TS and BT) have the same ID: PID_0001. When I use the disable command it disables both. What can I do?
EDIT: nvm, i got it. just use any other part of the hwid name, but NOT including any '&'s. For me, I had to use everything before the PID
Old 10-22-2007, 04:01 PM   #9
coucouillu's Avatar
coucouillu is an unknown quantity at this point
Problem with Bluetooth USB stick
Hi,
I have tried your solution but it doesn't seem to work.
After resume, the blue light of the stick is off ; I run the code with the right PID for my Bluetooth USB stick but I get a response that tell me that the device doesn't exist. Like it wasn't pluged.
I am obliged to unplug and plug the stick back to make it work.
Any ideas
Brice
coucouillu is offline   Reply With Quote
Old 11-20-2007, 12:50 PM   #10
aperali's Avatar
aperali is an unknown quantity at this point
this procedure can be done for non usb devices? like a ide dvd drive?
aperali is offline   Reply With Quote
Old 11-20-2007, 02:11 PM   #11
Yes it will work but you shouldn't be having problems with IDE drives.
@ Brice sorry I didn't get a notice to tell me you had posted. You need to be careful when it comes to BT as it installs loads of virtual devices. I am guessing that you didn't actually pick the proper device id of the stick itself. Been there myself in the past and it took a few attempts to get the proper device.
Old 11-20-2007, 02:24 PM   #12
aperali's Avatar
But I'm having. Sometimes when xp comes back from hibernation dvd desapear from windows explorer. Do you know what command line can be used to solve it, please? (or what could be happening). Thanks, Alex
Old 11-25-2007, 05:14 AM   #13
coucouillu's Avatar
Hi
thank you for your answer.
I am sure it is the right ID.
I think I have got a hardware problem.
If my computer is in hibernation since hours, if I turn on the pc, the BT stick is off.
If I reboot immediately after wake up (by reset or rebooting after complete wake up) the BT stick is on.
Old 11-25-2007, 06:30 AM   #14
Try disabling the usb root hub that the BT dongle is on and see how that works.
Old 12-27-2007, 05:31 PM   #15
Salmizar's Avatar
Salmizar is an unknown quantity at this point
Does anyone happen to have the PDF? the link seems to be down.
Salmizar is offline   Reply With Quote
Audigy 2 NX and hibernation backspace Car Audio 2 04-28-2006 01:56 PM
5 minutes to complete hibernation? WTF? DRWeside General Hardware Discussion 1 03-12-2006 10:36 PM
Question regarding Devcon & GPS hibernation Sonicxtacy02 GPS 1 08-15-2005 12:12 PM
Again DevCon with another problem Konrad General Hardware Discussion 3 02-04-2005 06:59 PM
Odd Off Topic-ness on Hibernation Vchat20 General MP3Car Discussion 1 01-31-2005 05:41 PM
Powered by vBulletin® Version 3.8.2
Content Relevant URLs by vBSEO 3.3.0
