02-20-2007, 10:03 PM
#1
Fusion Brain Creator
Lifetime bans: 4
Bans this month: 0
FAQ: Dimensions for Designing Your Own Custom Case
I think there should be some sort of sticky in the FAQ or maybe Fabrication forum with links to a bunch of PDF's or something that detail all the specifications and mounting holes of things such as:
3.5" Hard Drive
2.5" Hard Drive
itx/uATX/ATX Motherboards
M1/M2/Opus/DSATX PSU's
Case fans maybe
Just all sorts of stuff regarding building your own custom case. I found that I spent the longest time googling for 3-view drawing with detailed information about where the screw holes were located, maximum length/width/height, and that sort of thing.
Might be useful to others.
02-20-2007, 10:10 PM
#2
Lifetime bans: 4
Bans this month: 0
Mini-itx
02-20-2007, 10:13 PM
#3
Lifetime bans: 4
Bans this month: 0
Micro-ATX - uATX
02-20-2007, 10:23 PM
#4
Lifetime bans: 4
Bans this month: 0
FlexATX
02-20-2007, 10:24 PM
#5
That's very nice of you 2k1Toaster; why don't you start the FAQ thread yourself, though?
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
02-20-2007, 10:25 PM
#6
How about some 3d cad files. That would help me out when using PRO/E. So far ive had to manually build these 3D parts.
02-20-2007, 10:27 PM
#7
Lifetime bans: 4
Bans this month: 0
Well I wanted some input first, and also If everybody contributes what they have, then we can put together a comprehensive FAQ all at once.
That would be cool too. Go ahead and upload them. I will use all of the info posted here in the final FAQ.
Post away!
02-20-2007, 10:32 PM
#8
As fas PDF's go. It would be kewl to create a PDF file with everything you needed to know as far as measurements. Like a full on Document. Although living Threads are kewl for added knowledge. Too bad that doesn't always happen.
edit: I will have to see what 3D Cad files i have or can create for people. Does anyone have preference on 3D file type?
02-20-2007, 10:33 PM
#9
Lifetime bans: 4
Bans this month: 0
That would be a huge PDF!
If you can do it, go for it. But first we must gather all this info into 1 spot. Then we can optimize it.
02-20-2007, 10:54 PM
#10
Lifetime bans: 4
Bans this month: 0
M1-ATX and M2-ATX
02-21-2007, 12:10 AM
#13
http://www.frontx.com/diy.html <--A nice web site showing how to custom layout connections for a PC. Should be the same for carputers. Also the main part of this website has some cool conections that may be usefull for carputers. I checked mp3car store and didn't see stuff like this so i hope its okay to post. Delete if not ok.
http://www.frontx.com/cutout_dimension.gif <-- this is a picture of demensions for there connectors but im sure its standard connectors they use.
02-21-2007, 03:28 AM
#14
This is a fantastic thread. Congratulations to the 2 of you for taking the time to put all of this information in one place!
Carputer Haiku (thanks Ian Hughes)
Serious error.
All shortcuts have disappeared.
Screen. Mind. Both are blank.
02-21-2007, 06:16 AM
#15
Neither darque nor pervert
Lifetime bans: 981
Bans this month: 0
How about another entry in the FAQ Emporium....
Moved w/ redirect...
Nice job!
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
| Thread Tools |
| Display Modes |
Linear Mode
