Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Documentation and Tutorials
Old 06-30-2009, 03:19 PM   #46
customaudioman's Avatar
customaudioman is on a distinguished road
Im interested in an auto ride function. so I can have 3 height present. I just want to hit the button and go to that psi level. do any of you guys still use the v3?
customaudioman is offline   Reply With Quote
Old 06-30-2009, 05:39 PM   #47
bad_luck's Avatar
bad_luck is an unknown quantity at this point
Hey,
I've got airride in my car, and would like to make everything visible and operating through my PC. I use centrafuse now as a frontend. Are there any add-ons or something like that i can just use? I don't have much experience in programming so building it myself will be really hard if i have to start from scratch...
thnx, Bart
bad_luck is offline   Reply With Quote
Old 06-30-2009, 06:47 PM   #48
Quote: Originally Posted by bad_luck View Post
Hey,
thnx, Bart
Hey do you use gauges on your setup?
Old 07-01-2009, 01:40 AM   #49
question, how would you go about hooking up the air ride sensors. Do they hook to the analog input or digital?
Old 07-01-2009, 01:46 AM   #50
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Do the sensors have more than 2 discrete values? If so then how would a digital input work?
You need to use an analogue input.
Old 07-01-2009, 01:50 AM   #51
bad_luck's Avatar
now, i have a setup with simple 2 tanks, 4 airbags, a compressor, the airswitches and a display with 8 buttons on it and 4 digital gauges connected to a computer.
What i want to do, is put 4 2-way switches in my car, and make the pressure readable in centrafuse. If possible i would like to send signals to the airswitches, but that's not even really that important.
The normal switches will be so that I can adjust the rideheight even if I've got a problem with my PC, or if it hasn't started up yet (and I just have to move the car a few meters or so).
Old 07-01-2009, 02:08 AM   #52
I will be using the dakota digital sensors.
Old 07-01-2009, 02:48 AM   #53
are these the only senors that work with the FB? Im wanting to hook up five air sensors for my air ride. One for the tank, and the other four for the bags. I have to use the SEN-03-5 - Universal Pressure Sender with a 1/8" NPT fitting. Range: 0- 400 psi
Resolution: 2 psi How would I get the values to plug in?
Old 07-02-2009, 01:55 AM   #54
for the air ride sensor, would I need relays?
Old 07-02-2009, 02:17 AM   #55
2k1Toaster's Avatar
sensor = input
relay = output
Old 07-03-2009, 01:57 AM   #56
Okay so I hook all the sensors(5) to the analog inputs. The digital outputs of the FB I hook to the relays, then to the valves. would I be able to control the air ride system through the carputer( tell me how much air is in the tank and bags in psi)?would you be able to pushing the button in the program on the monitor to adjust the height of the car (leveling system)?
Old 07-03-2009, 02:33 AM   #57
2k1Toaster's Avatar
That's the idea...
Old 07-03-2009, 09:40 AM   #58
That's the idea...
How would I go about doing the code for the configurator? how do you find the values in psi?. for my type of air ride, I have to use Dakota Digital #SEN-03-5 0 - 400 psi, Universal Pressure Sender / 1/8. For my setup I cant use the 0-150psi pressure sender. will this sender still work? The code on the first page, will that work for the 0-400psi pressure sender unit?
Old 07-03-2009, 09:49 AM   #59
bad_luck's Avatar
Hi,
I guess you need some kind of device to hook everything up to a computer...
How, and where, can I get something like that? Or is there a scheme or something like that to make it myself ?
And, next step, can I get "standard" software that I can use in centrafuse ?? I have no idea where to start, please help....
grtz. Bart
Old 07-03-2009, 10:23 AM   #60
Hi,
grtz. Bart
just use the FB to hook to your computer to monitor and control the air suspension. Im not sure about centrafuse, I've never used the software. FB has it own software that you program and make what ever buttons you like it to do. I use streetdeck 2 for my frontend.
What do I need to hook up the air ride suspension? Maheriano Fusion Brain 8 12-29-2007 11:56 PM
DIY: Built a heater for my LCD nobb LCD/Display 42 10-27-2007 02:12 AM
2003 Civic CarPC (AIR RIDE) kumanan Show off your project 37 03-15-2007 11:20 PM
Air ride suspension keen70 Off Topic 6 02-14-2006 05:05 PM
Air ride suspension control? dragvette Newbie 1 01-22-2006 04:15 PM
