07-03-2009, 10:25 AM
#61
I might sound stupid now, but what is "the FB" ??
07-03-2009, 02:01 PM
#62
the fusion brain, the hardware that lets you control the air ride.
07-03-2009, 02:33 PM
#63
Fusion Brain Creator
Quote: Originally Posted by customaudioman
How would I go about doing the code for the configurator? how do you find the values in psi?. for my type of air ride, I have to use Dakota Digital #SEN-03-5 0 - 400 psi, Universal Pressure Sender / 1/8. For my setup I cant use the 0-150psi pressure sender. will this sender still work? The code on the first page, will that work for the 0-400psi pressure sender unit?
The code is for the 150psi unit. If you use something else than you will need to calibrate it, or find a pre-done curve. If you find a predone curve, then you can plug it into Excel and get an equation easily.
07-03-2009, 06:02 PM
#64
and where can i get this fusion brain ?
07-03-2009, 08:02 PM
#65
Both at our store (in my sig) and in the mp3car store (top banner).
07-03-2009, 10:41 PM
#66
how do I calibrate it? is there a pre-done curve? how did you get the code for the 150psi one?
07-05-2009, 01:57 PM
#67
anyone have info on this?
07-05-2009, 02:07 PM
#68
You calibrate it by reading in values and comparing it to known values. So put the system at X psi, read in the value, and therefore that value = that psi. Change system to psi Y, then read in the value, and therefore that value = Y psi.
You have to look at the sensor datasheet to see if they already have a curve. More than likely one exists somewhere, probably in psi vs. resistance.
We got the code for the 150psi by doing exactly as I described above.
07-05-2009, 03:54 PM
#69
The Last Good Gremlin
Good luck with that. Here's what I got.
This is what the engineers at Dakota Digital were able to find for me:
Resistance PSI
20 16
75 114
100 164
150 280
Someone probably needs to call them again and see if they ever found more data.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
07-07-2009, 10:44 AM
#70
Resistance PSI
20 16
75 114
100 164
150 280
I see most people with gauges in their cars(Chrysler 300) run like 90-98 psi int the front 100-106 psi in the rear with the 400psi sensors. I only can use this sensor, so are the numbers above all psi or resistance?
07-07-2009, 11:02 AM
#71
what equation in excel do I use?
07-07-2009, 11:40 AM
#72
The first number is the resistance you should see at the second number PSI.
In my excel spreadsheet, I took it to the third polynomial cause I started with three good points and got this equation:
y = 0.0035x^2 + 1.4409x - 14.099
The first set was added later after bugging the DD engineers for two weeks.
07-07-2009, 07:26 PM
#73
Is this for the 0-400psi sensors? also do you have a config file for the 0-400psi sensor or does any one have the 0-400psi sensor working in their car?
07-07-2009, 09:45 PM
#74
Yes this is what I came up with for the 400PSI sensor and I am no expert so someone else needs to verify it with the four coordinates provided above.
As far as I know, I'm the only one.
07-09-2009, 01:42 AM
#75
so your work in the car? Your able to see the pressure your sitting at? I dont have the sensor yet, will be getting soon. just want to make sure it works.
| Thread Tools |
| Display Modes |
Linear Mode
