Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Documentation and Tutorials
Old 07-10-2009, 04:47 PM   #76
customaudioman's Avatar
customaudioman is on a distinguished road
Gizmo, does your sensor work in the car hooked up?
customaudioman is offline   Reply With Quote
Old 10-16-2009, 12:53 PM   #77
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Well RIXS10 did send me a PM ontopic, so not sure, but I'll respond here just incase:
Quote: Originally Posted by rixs10
i just purchased one fusion brain, can a fusion brain be connected to an antenna to read rfid? this kit works good (4")but needs a larger antenna. keep up the good work!!
EBAY LINK REMOVED
RFID is a low power transmission system. 100mm is really the range you should be getting. You can get larger range with much much larger systems. Think about the theft deterrence systems in walmart by the doors and things like that.
The system you linked to outputs 12v. So you can use that as an input to the Fusion Brain if you send it through a voltage divider or you use the 4 channel isolator we sell (although you only need to use 1 channel for this).
-- Nick
What do I need to hook up the air ride suspension? Maheriano Fusion Brain 8 12-29-2007 11:56 PM
DIY: Built a heater for my LCD nobb LCD/Display 42 10-27-2007 02:12 AM
2003 Civic CarPC (AIR RIDE) kumanan Show off your project 37 03-15-2007 11:20 PM
Air ride suspension keen70 Off Topic 6 02-14-2006 05:05 PM
Air ride suspension control? dragvette Newbie 1 01-22-2006 04:15 PM
