Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Documentation and Tutorials
Old 04-06-2008, 05:54 PM   #1
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
MDX -- Linking multiple Outputs/Votes to a single Display Button
Quote: Originally Posted by Anonymous
Is it maybe possible for you to walk me thru in creating the variable links to trigger 2 outputs with one image.
1) Create a FB Instance
2) Create a Digital Output Instance. If you want to switfch 2 outputs, make at least 2 DO Instances.
3) Create a Variable Instance with initial value 0
4) Create a Display Button with Downwards Vote of changing the previously created Variable instance to +1
5) In the logic section, create a new IF/THEN instance
5b) Layout "If variable-get is equal to 1" and attach to the output node
5c) In this logic's then statement, create votes for changing however many or whichever Digital Output Instances you want to turn on or off.
6) Create a new IF/THEN instance
6b) Layout "If variable-get is greater than or equal to 2" and attach to the output node
6c) In this logic's then statement, create a vote for changing however or whichever Digital Output Instances you want to turn on or off (Generally opposite as above, but by no means is that required). Also create a vote to change this variable to 0
7) Save
8) ????
9) Profit
Transreflective Upgrade - The Review nameeri LCD/Display 119 06-07-2006 02:35 PM
Video Display Button in FrodoCam spaceskater FrodoPlayer 2 11-10-2005 02:13 PM
Multiple Display Home Theatre PC?? TaylorMade Off Topic 29 02-25-2005 09:56 PM
Lcd Display - Connection To Multiple Cameras Dluvr22 LCD/Display 2 08-19-2003 10:29 AM
non backlit LCD display? single line... bergeron76 LCD/Display 2 05-26-2002 04:59 PM
