Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Documentation and Tutorials
Old 04-22-2008, 02:24 PM   #1
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Fusion Control Centre Source -- Yep, all of it!
UPDATE:
Ok, here is the directory source files for the main MDX program, the MDX Configurator, the MDX Updater, and the FusionUSB.dll that we use to talk with the Fusion Brain. Folders are ordered by date, and project solutions and everything are all inside.
If you have a good contribution to the source, email us and we can put it into the next release.
Everything is open source here!
SOURCE: http://www.fusioncontrolcenter.com/MDX/Source/
Old 04-22-2008, 02:25 PM   #2
2k1Toaster's Avatar
Also all of these were created using Microsoft Visual Studio 2005 Pro, but should be openable in Express which is free.
The Solution (*.sln) file is included as well. The programs are all written in C# and the DLL is written in C++.
Old 06-25-2008, 01:05 PM   #3
Dan2008 is an unknown quantity at this point
I have downloaded the source files and get an error every time I try to extract MDX. The others extract fine. I downloaded it again just to make sure the download wasn't corrupted and still get the extraction error.
Can you check the extraction on your end and make sure the file is okay? I am using WinZip 11.2.
Dan2008 is offline   Reply With Quote
Old 06-25-2008, 01:20 PM   #4
2k1Toaster's Avatar
Just downloaded and tried again, works fine on this end.
I am using WinRAR 3.70
Old 06-25-2008, 01:25 PM   #5
I just tried again, this time leaving out the embedded archive files and it stopped on 81.png. I'll download WinRAR and see how it goes.
Old 06-25-2008, 01:30 PM   #6
That worked like a charm. I guess WinRAR does something that WinZip don't like.
Now, only 50 gadzillion lines of code to read...
Old 06-25-2008, 01:56 PM   #7
2k1Toaster's Avatar
Dont hate me, but I had a new source file uploaded, I forgot to update the link...
1st post is updated, and the link below is the most current: http://www.fusioncontrolcenter.com/M...2008-06-17.rar
Old 06-25-2008, 01:57 PM   #8
2k1Toaster's Avatar
It's not so bad.
I seperated it into regions to make viewing a bit easier and sort of explain. Comments are not really in there at all.
Old 06-25-2008, 02:03 PM   #9
I'm from the "if it was hard to write, it should be hard to read" school of programming.
Old 06-25-2008, 02:05 PM   #10
monzablue16v is on a distinguished road
Just downloaded it now shall stick it on my dev box and have a play with it, Good work can get everything in order then for when I order the new board between "some time soon and the not so distant future"
monzablue16v is offline   Reply With Quote
Old 06-25-2008, 02:05 PM   #11
That's okay...I don't have a brain yet so I can use MDX anyway.
I do have a question about the Configurator. I see an icon for "Rotate Image"...what does it do?
Old 06-25-2008, 02:08 PM   #12
2k1Toaster's Avatar
It does nothing now. MDX can read it in if you code for it manually, but the config cant spit out that code yet.
Basically it is an image rotated around a centre point. Think of a guage needle, something like that.
Old 06-25-2008, 02:24 PM   #13
What about something like a bar graph? I want to use something like blue->red for temperature gauges and digital output for most other stuff.
Old 06-25-2008, 02:26 PM   #14
2k1Toaster's Avatar
Multi-image
Old 06-25-2008, 02:29 PM   #15
Cool!!! Time to play...
Complete bolt in Screen/CPU/HD/PS - indash blk02si Fabrication 763 03-29-2009 01:51 AM
Upgrading Fusion Control Centre Website: Timeouts/404's perhaps... 2k1Toaster Fusion Brain 6 03-21-2008 09:40 AM
Update: 2-12-05.. Flash Support!... guino Road Runner 163 02-13-2005 01:21 PM
Could a Pre-AMP be used to control 2 audio source to AMP kingtut Car Audio 6 09-01-2004 05:09 AM
Questions for developers SuperG35 ME Archive 28 08-26-2003 11:12 AM
