Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Documentation and Tutorials
Old 09-04-2008, 01:13 PM   #1
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Ok there are 2 ways. First way use the wizard and be done with it. Or do it manually in the configurator. If you do one, then you don't need the other.
As for the markings on the board, those are pin header numbers. Nothing to do with the analogue inputs themselves. They follow what is in the manual and what is shown on the virtual brain:
Now to make a config with a temp sensor the easy way using the wizard:
You have to actually select your Fusion Brain from the connected ones or do it manually, but it would be easier for you by clicking the blue button. Also if you want a debugging screen, check the virtual button.
Save in MDX's root directory, and overwrite the one there (or rename the old one and use this new one).
That is it. The images, the text labels and the functions are all done for you.
Fusion Brain Latest Software MDX - Download Link 2k1Toaster FB Software 32 02-21-2009 12:05 AM
How to use a configuration file created by the Configurator with MDX 2k1Toaster FB Documentation and Tutorials 15 09-08-2008 05:36 PM
Fusion Control Centre Uber MDX -- Now with Threads and Timer Updates :) 2k1Toaster FB Software 0 08-31-2008 02:32 AM
Quick overview of the Fusion Control Centre MDX Configurator 2k1Toaster FB Documentation and Tutorials 0 06-06-2008 06:17 AM
Real temperature solution - what do you think? dmurray14 Centrafuse 10 01-24-2005 10:38 AM
