Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Documentation and Tutorials
Old 03-18-2009, 11:57 PM   #1
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
can't run configurator
Hey guys,
trying to test out the software before my purchase. I'm currently running windows vista (blah) and logged in as the administrator.
after a fresh install and reboot i try to run configurator and i get the following error:
"MDX Configurator does not have the neccessary permissions to write the registery. Please close the program and run as an administrator"
i hit ok and get:
"FCC Uber MDX Configurator has stopped working"
and it asks if i want to check online for a solution or close the program
and here are the details:
Code:
escription: Stopped working Problem signature: Problem Event Name: CLR20r3 Problem Signature 01: fcc uber mdx configurator.exe Problem Signature 02: 1.0.0.247 Problem Signature 03: 49aa2039 Problem Signature 04: mscorlib Problem Signature 05: 2.0.0.0 Problem Signature 06: 471ebc5b Problem Signature 07: 3404 Problem Signature 08: 15a Problem Signature 09: System.UnauthorizedAccess OS Version: 6.0.6000.2.0.0.256.6 Locale ID: 1033
i'm stumped, any help?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 03-19-2009, 12:25 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Running as administrator and being logged in as an administrator are completely different things. You must do as the program says and run it as an administrator.
You are getting this message because you have UAC enabled. Right click the program then in compatibility check the "run as administrator" box. Or you have to right click the program/shortcut and choose "run as administrator" everytime.
An "administrator" user group in Vista means diddly squat. You need to run as a true admin.
Old 03-19-2009, 01:18 AM   #3
MySQL Error
scott_fx's Avatar
thank you, it worked
M10k
My Car Pc Install
Fusion Control Centre MDX & Configurator -- Major Update 22/12/2008 2k1Toaster FB Software 41 01-11-2009 03:46 PM
How to use a configuration file created by the Configurator with MDX 2k1Toaster FB Documentation and Tutorials 15 09-08-2008 05:36 PM
UPS run from inverter? FyreDaug Power Supplies 28 01-18-2007 07:03 PM
what software in run up front(touchscreen) g1smo Newbie 7 02-22-2005 01:17 AM
Is it possible to run every prog embedded? memy Road Runner 8 02-13-2005 07:19 PM
