Quote: Originally Posted by
Red_Baron
I want to do something simular with the hvac controls, but I don't want to use anything from the old controls. All the knobs are variable resistors, and you stated those can be controled by the brain right?
Attached is the pin outs for the controls I was thinking of replacing with the fusion brain. Thanks for any help you can give me, and thanks for the great product. I hope to be using it soon in my carpc install.
Red Baron
Looks your fan switch closes contacts across a tapped resistor like most. 4 speeds right, probably gonna use 4 digital outputs to close contacts in succession across the resistor, full resistance= low speed; all contacts closed (resistor shorted) =max speed. Very possible. This knob is not itself a variable resistor.
The switch that controls the position, the 'mode' switch is just a sequenced switch that opens and closes discrete outputs, this is exactly the kind of stuff that the brain is designed for. Gonna need more than that wiring table to be sure what to use and how, but it's very possible. This knob is not a variable resistor.
The knob that controls temperature may be not be a resistor, I say that because:
"TEMPERATURE SWITCH
The temperature switch controls the temperature door position that will be used to regulate the air conditioning system's discharge air temperature. The switch includes a rack amp; pinion and a cable"
Sounds like it uses a bowden cable setup, and if it does, your one of the unluck ones that is going to have to set up a servo on the blend (temperature) damper (flap) at the airbox. If not, if it is a variable resistor, then, you're going to have to wait until the make the analog output add-on available to replicate it.
For servo control of dampers, I think some people have done it using mastero's aircon. Use the fusion but check out the control of HVAC via serial connection thread in the Hardware Design forum ( search: servo ). ]
Or Check out the manual for the full automatic climate control version for your vehicle or one very similar, maybe you can swap out some OEM stuff if this is the case.
