Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Outputs
Old 06-07-2008, 10:22 AM   #1
Bxsteez will become famous soon enough
Fusion Brain and Window Contorls
Maybe i'm thinking this is too complicated but how would you hook up window controls? Would it just be a digital output connection? I don't know too much about car circuitry but does the resistance just increase as the physical resistance increases so the window stops trying to go up when its already at its maximum height?
~The Build Process Begins~
http://www.mp3car.com/vbulletin/newb...you-think.html
~The Build Process Ends~
http://www.mp3car.com/vbulletin/show...completed.html
Bxsteez is offline   Reply With Quote
Old 06-07-2008, 10:45 AM   #2
BLACKonBLACK98 is an unknown quantity at this point
heh. i'm just gpoing to tag along with you.
i was wondering the same thing but was just gonna wait until i got it. is it possible for the outputs to act as a momentary switch?
actually i know the answer is yes since i have seen the air ride posts and whatnot. in for explanation.
*edit - just found the answer in a thread i had not seen before. the outputs are configurable to act as momentary switches, meaning power is only output while you are pressing the button. so basically you would just run the output through a relay and connect the 12v to the window motor, 1 for up, 1 for down. not sure how a negative switched setup would work, but they are less common.
BLACKonBLACK98 is offline   Reply With Quote
Old 06-07-2008, 11:07 AM   #3
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
For a negative based setup, you would use two relays to trigger your window down switch. As if when you're engaging the relay, you're pressing the switch on your door panel.
colin is offline   Reply With Quote
Old 06-07-2008, 11:18 AM   #4
ahhh yes... makes perfect sense.
Old 06-07-2008, 11:27 AM   #5
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
and for automated windows, put a current sensor on the motors. When current draw gets to about 150% of normal, it is fully up or down, so turn off output.
Old 06-07-2008, 11:30 AM   #6
Maybe its my lack of experience with car electronics but i'm slightly confused. So for window control you would need relays for both up and down operations? I assume this is because the window circuitry is a high current circuit? And negative the switched setup has completely confused me.
Old 06-07-2008, 11:31 AM   #7
2k1Toaster's Avatar
yes you would need 2 relays per window for most setups. Also 1 current sensor for each window you want to "auto"
Old 06-07-2008, 11:41 AM   #8
WuNgUn's Avatar
WuNgUn is on a distinguished road
I would use load-sensing relays...they'll latch on until the load spikes, then shut off automatically. This way you don't need a feed-back loop into the Fusionbrain, just a pulse output...
Alternatively, you could use a Directed (DEI) 530T power window kit...
It'll control 2 windows both up and down...
When I get my HVAC setup in my front end, I plan on having the PC ask me if I want to roll the windows up when it senses I've turned on the A/C...
Maybe even a voice command to roll them up or down too?
Or speed sensitive roll up? The faster I go (monitoring GPS speed), the further the windows close, to limit noise and buffeting...
WuNgUn is offline   Reply With Quote
Old 06-07-2008, 01:57 PM   #9
colin's Avatar
Well first things first, do you want auto-up and auto-down. If yes, do your current window switches provide these functions? If yes, hook the relays up to the window switches, itll cost you almost nothing. If no, then you need to do current sensing and then things become a hassle...
Old 06-07-2008, 02:02 PM   #10
I'm thinking where i'm confused is the car circuitry itself. I've never really looked into how the windows actually go up and down. I just assumed it was a motor pulley system or something of that nature. maybe i should research the car end a little more
Old 06-07-2008, 03:25 PM   #11
Does anyone have any sort of wiring diagram cause i'm just not able to see how these relays are going to be connected to the fusion brain and control the windows. If i'm understanding this correctly there is one motor and reversing the polarity on the motor determines whether you are going up or down. I would think i'd need two relays for up and two relays for down but maybe i'm just way off. Any insight anyone?
Old 06-07-2008, 03:41 PM   #12
greenman100 is on a distinguished road
First of all, this is doesn't belong in "Documentation and Tutorials"
You need either 4 SPST relays for each direction and each window, or 1 DPDT relay for each direction/window.
We only sell SPST relays on our site. You probably should pick up a DPDT relay on your own, and use the 2-pin cables we sell to hook it up.
greenman100 is offline   Reply With Quote
Old 06-07-2008, 06:18 PM   #13
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
I don't know if all cars are like mine but I'm sure most are. The switches all short to ground in center pos. Each wire going to the motor needs to be cut after the switch. Switch to N.C. side of relay, and motor to the sweep thing on the relay. That way it's like it's not there when not in use. Then the N.O. side goes to battery. Energize the relay and it gives power to the motor and the other side is already grounded through the other relay through the switch. If you have express down, you need to patch in after it. You must make the cut on the wire going to the motor.
Here's a schematic:
Highslide JS
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 06-07-2008, 08:45 PM   #14
Ok from looking around at a few websites and a datasheet i finally understand how this would work with the DPDT relay. I apparently was thinking of it as a SPST and in that case i would need 4 for up and 4 for down. Thanks everyone
Old 06-07-2008, 09:15 PM   #15
Curiosity's Avatar
Automotive SPDT will work fine. 2 for each window. 1 for up. 1 for down.
Win $25 for designing the best skin for the Fusion Brain's Software! 2k1Toaster FB Skins 68 04-23-2009 01:38 PM
How to add a Fusion Brain instance to your configuration file 2k1Toaster FB Documentation and Tutorials 0 06-07-2008 09:42 AM
Quick overview of the Fusion Control Centre MDX Configurator 2k1Toaster FB Documentation and Tutorials 0 06-06-2008 06:17 AM
How to Open Debug Console and Raw Window for Fusion Brain 2k1Toaster Fusion Brain 8 10-27-2007 08:48 PM
