Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Outputs
Old 07-07-2008, 05:07 PM   #1
h3rk will become famous soon enough
Direct output connections.
There are three different output applications I am planning to implement, and they are all a little different. In each of them I am looking to pull a line low on a PCB, using a Brain's switched low side of a digital output.
Ignore the periods.
1. +5V-----10K----|-----10K-----IC
..........................+----Low pin on FB Digital output
.........................SW
........................GND
and I figure since .5mA is <<< 200mA this will work.
2. GND----SW-----0 ohm-----BCM(IC)
.....................+-----Low pin on FB Digital output
I haven't torn apart the BCM in question, but I'm pretty sure the output current is low (the pin is spec'd at 5V/0V in the service manual)
3. This one's tough for ASCII, so I will refer to a drawing that I have up already.
I want to tie the collector of TR752 or pin 1 of comparator IC3 to ground with the low pin on FB Digital output.
10V /500 = 2mA
I think the max current per output is like 200A so I think that it is safe, but I put it out there for feedback, and as a potential example of things that you can do with the outputs, not requiring the use of relays.
Last edited by h3rk; 07-08-2008 at 03:40 PM. Reason: ascii art is tough when the forum gobbles up white space
h3rk is offline   Reply With Quote
Old 07-08-2008, 01:37 PM   #2
I guess the question is; will that darlington array bias correctly with something other than 12V on the collectors? If not, I suppose I will have to bias another transistor in my custom interface with 12V so that it (new transistor) turns on when ground from the output is switched, baised properly for sinking the 5V or 10V to ground.
Am I making sense?
Old 07-08-2008, 06:39 PM   #3
Fusion Brain Creator
greenman100 is on a distinguished road
At first glance, your approach would be fine.
greenman100 is offline   Reply With Quote
Old 07-08-2008, 06:55 PM   #4
Cool, thanks for looking at it for me.
I'll get a chance to try it out in the next few days, I'll report back here on how it goes. I don't see much potential for overcurrent or any other bad events by trying it. I'm thinking worst case, they just dont work.
Old 07-30-2008, 03:21 PM   #5
Can I take the switched side of an output to ground, regardless of the state of the output, without hurting anything? + side is not used in this case (see above). Just making sure.
Old 07-30-2008, 04:43 PM   #6
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
yes you can put it to ground, because all it does it switch ground. So if it is grounded, and you switch the ground, it will be double grounded?!
Unless I am not understanding what you meant.
Old 07-30-2008, 05:10 PM   #7
Nope, you understood. That's what I thought, I just wanted to make sure.
GPS to cell phone output somehow ??? gadget General MP3Car Discussion 69 06-11-2007 09:22 AM
XM Direct Character Length? chuckster Road Runner 2 05-02-2006 09:32 PM
Possible to split XM Direct cable to computer and XM commander? Jemmi General Hardware Discussion 3 12-14-2005 03:07 PM
Is all coax/optical spdif output created equal? Choser General Hardware Discussion 26 12-19-2004 03:48 PM
Car Alarm Aux output and Shutdown controller MatrixPC Power Supplies 0 05-09-2004 08:36 PM
