Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Outputs
Old 08-25-2008, 12:31 AM   #1
blob is on a distinguished road
Output Status When Off
Clearly the FB doesnt function when the pc is off.
When the pc is shutdown does the FB retain the outputs at shutdown and similarly at startup until the software reloads and any changes are made.
Or is it that as soon as the software is closed/pc is shutdown that output status is null.
thanks.
blob is offline   Reply With Quote
Old 08-25-2008, 12:38 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
The outputs turn off when the software closes.
When the software is re-opened it uses the default state set in the configuration.
So the program is closed on shutdown and reopened if you have it run at startup, or have it embedded in a software that runs at startup.
How to get 13V-17V on the primary output of your CNX-2140 - Solution inside. hari-bhari Power Supplies 7 01-03-2009 02:52 PM
using amp output to input? Xprime4 Car Audio 6 12-21-2007 10:26 AM
M-Audio Fast Track Pro: 2.1 Output Possible? speedycheater General Hardware Discussion 2 12-10-2007 02:07 PM
Aux-in Analog audio... will it output from the SPDIF on mainboard? coachreed General Hardware Discussion 0 05-07-2005 10:57 PM
No lcd output JettaMP3 General Hardware Discussion 4 03-12-2001 03:27 PM
