Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Outputs
Old 09-13-2008, 10:47 AM   #1
djurchicprelude is on a distinguished road
Garage door opener
I would like to tap my garage door opener into my fusion brain. question i have with that is what kind of relay do i need? or mabye what i need in general. what i mean is, with a general on/off switch the relay sends a constant voltage signal to keep something on. but with the garage door opener it just needs it for a second. how would i go about doing that. thanks
sorry for the horrible explanation. i dont know to many technical terms. thanks again
djurchicprelude is offline   Reply With Quote
Old 09-13-2008, 11:12 AM   #2
Fusion Brain Creator
greenman100 is on a distinguished road
Just use a regular relay, and tell the fusion brain to pulse the output for a certain numbr of milliseconds
greenman100 is offline   Reply With Quote
Old 09-13-2008, 12:29 PM   #3
thanks very much!!
Old 09-13-2008, 01:34 PM   #4
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Exactly.
This is what I will be doing myself soon. I hope you have seen the remote control part of the program so you can open it from anywhere in the world.
Old 09-13-2008, 05:34 PM   #5
Quote: Originally Posted by 2k1Toaster View Post
Exactly.
Actually I just orderd the fusion brain and am inpationtly waiting for its arrival. I read alot about it but have not ran into anything about the remote control part. thats excelent!!!
Old 09-14-2008, 12:01 AM   #6
2k1Toaster's Avatar
Here is a link for the remote control information: http://www.mp3car.com/vbulletin/soft...interwebz.html
Old 10-23-2008, 01:43 PM   #7
Hey I wanted to come back to this now since I got my FB working in my car and am loving it. How would I go about "pulsing the output for a certain numbr of milliseconds " for the fusion brain? and also it will still work with the road runner and RRfusion correct? thanks!
Old 10-28-2008, 02:09 PM   #8
Ive searched through the configurator and cant find anything on pulsing???
Old 10-28-2008, 02:22 PM   #9
i'm pointing Nick to this thread
Old 10-31-2008, 12:10 AM   #10
2k1Toaster's Avatar
To pulse you need to make some logic. First a button that changes a variable to true or to 1 or something other than false or 0 (or something you determine to mean off) as well as turn on the output.
The logic then will monitor that variable that was changed to lets say 1. If that variable is 1, then another variable will be incremented. If that variable is 0, then the counting variable is 0.
Another piece of logic that will now monitor this count variable. If the variable is over X where X is a number like 10, then turn the output off.
So that 100 number is how long the digital ouput is on for. If the output timer is set to fire every 100ms (0.1s), then it takes 10 counts before the digital output turns off, and therefore (100ms per logic iteration) x (10 logic iterations) = 0.1 * 10 = 1 second pulse.
Adjust the numbers for different values. If you change the timer to fire every 50ms still counting to 10, then it would only pulse for 0.5 seconds. Or Change the count to 42 and with the 100ms timer would be 42 * 0.1s = 4.2 seconds.
Garage WiFi KingofCorona Wireless Communications 3 11-29-2007 06:16 PM
garage door opener integration pimpmode General MP3Car Discussion 2 05-17-2005 02:29 AM
Garage door torsion spring MatrixPC Off Topic 4 02-11-2005 06:54 PM
Controlling garage door ... electron Newbie 19 09-17-2004 11:13 PM
