Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Outputs
Old 04-06-2009, 03:04 PM   #16
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
How are you determining the variable is always correct? Are you using the variable debug window?
The minimum vote time for each should be set low in your case since you are doing absolute values not increments.
The main timer is how long before each output evaluates what to do. If you press the button twice before the main timer evaluates, your votes cancel eachother out, and no difference will happen.
Old 04-07-2009, 10:56 PM   #17
ATT41's Avatar
ATT41 is an unknown quantity at this point
I'm showing a display showing the value of the variable.
I've tried both ways, using increments and changing the value from -1 to +1. both ways always change the variable, but sometimes don't trigger the output.
If I just leave the button pressed in (constant input is "on") the variable changes ever second, but every 3rd or 4th second, the output doesn't trigger. Changes each time, it isn't constant. Would it help if I sent you a copy of my config file?
[H]
____╔══════╗____
OOO/ATT41\OOO
ATT41 is offline   Reply With Quote
Old 04-07-2009, 11:41 PM   #18
2k1Toaster's Avatar
IO isnt continuous. When you press it, it triggers and registers the vote. The output averages the votes to determine what to do.
If you are holding it down, you are essentially sending a random number of votes. Every so many milliseconds as said by the io timer, it then evaluates all the accumulated votes. Since you are sending off/on votes, it will be completely random on whether or not there are more on, or more off, or an equal amount (no change).
So you are probably seeing the output change but it is more than likely random to what it changes or not changes to.
Old 05-08-2009, 03:05 AM   #19
ATT41's Avatar
OK, I am up to the stage of installing the the button in my dash, that will control the on/off for my amplifiers.
I have 4 buttons on my dash:
Button 1: Turn off 4 Ch amp
Button 2: Turn off Mono amp
Button 3: Turn on both amps
Button 4: Turn off both amps
This should work fine for me, the single button for on/off just wasn't working out.
I need to know how to wire the FB to understand the button has been pressed. When, for example, Button 1 is pressed, it will complete the circuit for input #0 which should show in MDX the voltage being 5v, but this only requires 2 wires, but there are 3 on the board. Am I missing something?
Note: I am using Ver3 FB but it looks like Ver4 has 3 pins as well.
[H]
____╔══════╗____
OOO/ATT41\OOO
2000 Mitsubishi Verada Car PC Install MitchellO Show off your project 17 03-25-2009 01:40 AM
car alarm remote to turn on computer rsx_03 Input Devices 9 08-28-2008 12:15 PM
I ditched the 2140 & made my own SSC... loginfailed Power Supplies 16 02-03-2008 01:03 PM
Lilliput buttons light up with car lights on? dtran01 LCD/Display 21 02-26-2005 06:25 PM
how can I wire up power inverter to secondary battery, but turn on when car starts? CrazyModGSR Power Supplies 4 10-29-2004 09:10 AM
