Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Outputs
Old 04-03-2009, 03:13 AM   #1
ATT41's Avatar
ATT41 is an unknown quantity at this point
Buttons on my dash to turn on my car amplifiers
Ok, so I am using the FB at the moment to trigger outputs (relays) for my amplifiers.
I want to use a spare switch in my car's dash to do the same thing (as if I were clicking the button on the screen to turn on/off an output).
The switch in my dash seems to only complete the circuit when the button is being pressed, once I stop pushing down the button, the circuit it broken.
So I want MDX to change the output status as if the button is like a "down click vote" and not change until the next "down click vote"
Hope this makes sense.
[H]
____╔══════╗____
OOO/ATT41\OOO
ATT41 is offline   Reply With Quote
Old 04-03-2009, 03:29 AM   #2
Crinos is an unknown quantity at this point
Not quite sure of what you are trying to do here...
Just to clearify...
You want a hardware button, to do the same task as a software button via FusionBrain does?
If so the case, you need a button that sends a puls signal while beeing pressed. then a system that register the puls, and have a memory of on/off state, and out of that a logic that sends a solid 12V to amp if "on" and cut the signal if "off".
Now.. This might seem a bit more complicated than it realy is... There are some stores where you can buy a logic relay that can do this task for you.
How this will work togeather with FusionBrain... I have NO clue off..
Crinos is offline   Reply With Quote
Old 04-03-2009, 03:54 AM   #3
ATT41's Avatar
hmmm... not quite.
I think what I am trying to say is, I want an output to be triggered by an input.
Once the input is active (lets say 12v) the FB will trigger an output.
[H]
____╔══════╗____
OOO/ATT41\OOO
Old 04-03-2009, 04:16 AM   #4
ATT41's Avatar
OK, I think I am getting somewhere now,
using a new root function that will trigger a predefined output if a certain input is greater than 5v (I now realise you can have a input with 12v)
gotta play around with it a bit though.
[H]
____╔══════╗____
OOO/ATT41\OOO
Old 04-03-2009, 09:52 AM   #5
Fusion Brain Creator
greenman100 is on a distinguished road
do not do this. 5v is the max.
greenman100 is offline   Reply With Quote
Old 04-03-2009, 11:01 AM   #6
ATT41's Avatar
oh ****, I meant to say can't,
but it appears I have found a way to do it. I'm going to have an input logic "if > 2v, vote amp relay on",
and I will have a second button in may dash that will do the same, except amp relay will turn off.
just need to find a 5v source somewhere tho...
[H]
____╔══════╗____
OOO/ATT41\OOO
Old 04-03-2009, 11:03 AM   #7
take it off the FB analog inputs
Old 04-03-2009, 11:08 AM   #8
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
The virtual button in MDX acts like a momentary, or the physical button?
If you want the button to act like a latch, then have the button input increment a variable. Set the minimum time between votes to something like a second or more. Then another logic that says if the variable is 1, turn on output. Another for if variable >= 2, variable = 0. That will latch.
Old 04-04-2009, 12:14 AM   #9
ATT41's Avatar
Great!
Makes sense, but I'm having trouble making MDX do that.
The first input logic will be "if amp switch is > 2v, then change variable +1"
it seem that when I punch that it, it doesn't add 1 to the variable value, it replaces it with the number 1.
Or am I doing something wrong? - I can host the config file if it helps?
[H]
____╔══════╗____
OOO/ATT41\OOO
Old 04-04-2009, 01:36 AM   #10
ATT41's Avatar
Looks like I have figured out a way to do it
For anybody else trying the same thing, this is what I am going to test with my FB (seems to work fine with the virtual brain so far).
Only problem I forsee is holding the button down too long. but I shouldn't be holding the button for longer than 1 second I suppose.
[H]
____╔══════╗____
OOO/ATT41\OOO
Old 04-04-2009, 01:40 AM   #11
2k1Toaster's Avatar
"value = +1" means "value equals positive 1"
"value = d+1" means "value equals value plus positive 1"
Old 04-04-2009, 01:48 AM   #12
ATT41's Avatar
thanks for that!
I ended up just replacing the numbers with 1 or 0, rather than adding and then changing the variable.
do you seem some flaw in the way I have done it?
[H]
____╔══════╗____
OOO/ATT41\OOO
Old 04-04-2009, 01:51 AM   #13
2k1Toaster's Avatar
thanks for that!
nope that works fine as long as it stays synchronized which it should unless it glitches from what I can see.
Old 04-04-2009, 02:00 AM   #14
ATT41's Avatar
well I'll see how it goes with the real thing, I just hope it doesn't miss a "then" statement.
[H]
____╔══════╗____
OOO/ATT41\OOO
Old 04-06-2009, 05:46 AM   #15
ATT41's Avatar
So I have been testing it for a little while. Does seem to open the relay on every click, seems to not register some times. I may have my vote timings incorrectly. I noticed you can change the vote timing for the whole file, or you can change the timing for each logic. Any timers I should have specifically?
seems the variable is always correct, and always changes. Sometimes the output isn't triggered through.
[H]
____╔══════╗____
OOO/ATT41\OOO
2000 Mitsubishi Verada Car PC Install MitchellO Show off your project 17 03-25-2009 01:40 AM
car alarm remote to turn on computer rsx_03 Input Devices 9 08-28-2008 12:15 PM
I ditched the 2140 & made my own SSC... loginfailed Power Supplies 16 02-03-2008 01:03 PM
Lilliput buttons light up with car lights on? dtran01 LCD/Display 21 02-26-2005 06:25 PM
how can I wire up power inverter to secondary battery, but turn on when car starts? CrazyModGSR Power Supplies 4 10-29-2004 09:10 AM
