Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Outputs
Old 06-18-2009, 01:16 PM   #1
cgalpin is an unknown quantity at this point
Relay wiring
I can't believe I'm asking this but I am unable to get my relays working
This is pretty simple stuff so I hope it's not me doing something stupid, but it's likely I am
The relays (purchased with my FB) have 3 spade connectors
COM (common)
NO (normally open)
NC (normally closed)
My understanding and expectation is that if I have a working circuit (lets say a light bulb) and I take the wire providing 12v and put the relay in series, I can turn it on and off. Like I said, simple stuff (baby steps).
So I connected one end to COM and the other to NO. When I trigger the output port on the FB, the led lights, the relay buzzes, but my bulb never turns one. I have verified there is no voltage with a multi-meter. The NC side is always hot. I have tried 3 relays and don't expect this to be a hardware issue as they all behave the same way.
What am I doing wrong? Is it that the relay isn't really engaging? I have looked at the FB4 manual and tried all 4 possible jumper combinations for P13 if keeping the jumpers in the same orientation as shipped and there is no difference (I have 12v to P1).
Thanks,
charles
cgalpin is offline   Reply With Quote
Old 06-18-2009, 01:28 PM   #2
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
The relay shouldn't buzz, it should just click... sounds like either bad relay, or not enough juice to the coil side of the relay.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 06-18-2009, 01:29 PM   #3
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
you do have it grounded too right? Just making sure...
Also what power source are you using to power the FB?
Old 06-18-2009, 01:41 PM   #4
I am just bench testing right now.
I'm using a power supply from an old hub/switch that puts out 12V DC (800mA). I assumed this provides ground as well. I'll try hooking it up to a car battery.
thanks,
charles
Old 06-18-2009, 01:59 PM   #5
2k1Toaster's Avatar
thanks,
charles
No I meant on the relay side. Nothing would work if the wall wart wasn't grounded!
Basically without the relay, does the light work? It should always be on. Then cut one of the wires and put the relay between it.
Old 06-18-2009, 02:01 PM   #6
Yes the circuit works fine before I introduce the relay, LOL. I do feel pretty stupid right now, but honestly I'm not THAT stupid
No difference powering the FB from a car battery - relay whines. What's the max voltage I can apply to the relay trigger pins to test it directly (without the FB)?
Old 06-18-2009, 02:05 PM   #7
2k1Toaster's Avatar
The 12v wall wart you are powering it from should be enough to trigger the relay by itself.
Old 06-18-2009, 02:34 PM   #8
digital79 is an unknown quantity at this point
You connect the relay coils in series? If that's the case, each coils is getting way less than 12VDC (voltage/#of relays), so coil does not make enough magnetic field for the relay contact to move.
Did you test each relay individually?
digital79 is offline   Reply With Quote
Old 06-18-2009, 02:42 PM   #9
No probably bad choice of words on my part. By series I meant I introduced the relay into the starting circuit by "cutting" one of the lines.
Testing with a single relay.
My circuit is simply this
12v -- bulb -- ground WORKS!
12v -- COM -- [ relay ] -- NO -- bulb -- ground BULB NEVER COMES ON
12v -- COM -- [ relay ] -- NC -- bulb -- ground BULB NEVER GOES OFF
I have bypassed the FB and still have the same behaviour though when applying 12v to the trigger pins. Totally stumped....
The only difference I noticed with the FB is I hear a hum when the relay is turned on. With direct 12v I hear a very soft click (but have to put my ear close to it to hear it)
Old 06-18-2009, 02:44 PM   #10
try this
http://electronics.howstuffworks.com/relay1.htm
Old 06-18-2009, 03:06 PM   #11
Although the pettiness of my problem can't be confidence inspiring, I really do know how a relay works. Now it's certainly possible I am not connecting to the right connectors, but I don't think so. If you want to look at a reference that is a little more relevant to this problem (given the relay marking I have) please look at this and let me know what you think.
http://www.kpsec.freeuk.com/components/relay.htm
The relays I have are triggered by 2 wires soldered to the bottom - hard to screw that up if I do say so myself. I started off triggering this with a FB but have also applied 12v (and ground) to them directly with no better results. These are not shown in my diagrams.
For the rest of it, the page above matches it pretty well. I have 3 connectors, COM, NO, NC, which I expect to work as described.
2k1Toaster, do you see any problem with the way I am testing or have these wired up?
thanks,
charles
Old 06-18-2009, 03:10 PM   #12
Trigger pins are electrically insulated from NO, COM, NC. You also need to provide power source to the bulb
EDIT: what type of relay is it? Any model number?
Old 06-18-2009, 03:14 PM   #13
Cerberus's Avatar
Cerberus is on a distinguished road
If you wire it 12v -- com -- no -- bulb -- ground and then power the relay
coil from the 12v direct (no arduino at all) and the bulb doesn't come on...
then quite simply the relay is goosed!
Or it's some mad relay that needs huge voltage across it's coil.....
C
Cerberus is offline   Reply With Quote
Old 06-18-2009, 03:17 PM   #14
Yes which is why I showed you
This works fine. All I did was add the relay to the circuit. It still has ground.
C
Yes this is why I am stumped. This should work! But 4 relays act the same way. I guess I'll try the last 2 to be sure
Old 06-18-2009, 03:20 PM   #15
It's the ones the FB folks sell.
Potter & Brumfield
T9AS5D22-24
FAQ: RELAYS; how they work and how to wire it up... FusionFanatic The FAQ Emporium 12 10-11-2009 10:25 AM
Need Help - BMW's Signal Differential Speaker Wiring, Amps and SVEN4 lloydy Car Audio 8 02-14-2006 07:43 PM
wiring a relay please help 04scooby Newbie 6 01-30-2006 11:56 PM
if you designed a vehicle's interior and wiring, how would you do it? stapan General MP3Car Discussion 7 12-26-2005 02:56 PM
Took the plunge - ordered my relay card BeaverWise General Hardware Discussion 7 01-06-2005 10:15 AM
