Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Outputs
Old 09-15-2009, 10:20 AM   #1
bigfarmerdave is an unknown quantity at this point
Fusion Brain "email output" problem
Playing around with my Fusion Brain ver 4, I've used the Fusion Control Center Configurator to compare an input value with a reference. When the input goes above the reference, I have the output configured to send an email. The problem is, it continues to send emails as long as the input is larger than the output. Hence, LOTS of emails pile up. Is there a work around to limit the number of emails sent? Also, is there any way to send a text message instead of an email?
bigfarmerdave is offline   Reply With Quote
Old 09-28-2009, 11:09 PM   #2
yonu is on a distinguished road
ok I am not sure about the multiple email but as to sending a tet check your cell provider i know for instance if you send an email to yournumber@tmomail.net and are on tmobile us then you will get a test or mms depending on the content
sorry i couldn't be of more help,
yonu
yonu is online now   Reply With Quote
Old 09-28-2009, 11:14 PM   #3
justchat_1 will become famous soon enough
Haven't done fusion brain work in awhile but you should be able to use a flag or a boolean or whatever the equivalent is on the device. You set it to true after the first email is sent and then don't send emails if its true next time around. Just remember to set the flag to false when the voltage drops under the reference.
openMobile - An open source C# Front End
- Currently Recruiting Developers -
Available for download on sourceforge
justchat_1 is offline   Reply With Quote
Old 09-29-2009, 02:19 AM   #4
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
That would work for a one time message yes.
Another way is to set the "minimum_delta_vote_time" to a large number. That way the email is only sent every "large number" milliseconds. So set it to something like every hour (3600000ms), and you get one every hour. Or per day or something like that.
Fusion Brain and iBus nemo1 Fusion Brain 7 12-15-2008 11:05 AM
Vista won't see the Fusion Brain Ineffigy Fusion Brain 6 11-26-2008 07:39 AM
Fusion Brain Version 4 ready for Beta Testers! greenman100 Fusion Brain 15 11-13-2008 11:21 PM
Fusion Brain Encloser djurchicprelude Fusion Brain 12 10-27-2008 08:42 AM
using fusion brain to delay turn on of amp theheel Fusion Brain 9 08-27-2007 10:33 PM
