03-27-2008, 04:38 PM
#61
Terminal flasher
any chance we will see rain sensors for a rain-sensing wiper setup?
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
03-27-2008, 04:47 PM
#62
Fusion Brain Creator
make your own.
put two bare wires real close to each other, one to input, one to +5vDC
when it rains, the input will increase
when it's not raining, the input will go to zero
03-27-2008, 04:57 PM
#63
Terminal flasher
Quote: Originally Posted by greenman100
make your own.
you know ur gonna burn my house down talking like its that simple right! lol
03 Acura RSX Coupe
03-27-2008, 05:08 PM
#64
it really is that simple
03-28-2008, 10:17 AM
#65
does rainwater have enough ions in it to be conductive?
03-28-2008, 10:30 AM
#66
Terminal flasher
ok so i run two small gauge wires up under my wiper cowl that are bare. Run one wire to the +5v and one to input leaving the switched ground disconnected. test the input voltage without rain and thats my floor. Then when it rains both the 5v line and the input line get wet, and this causes the input line's voltage to increase to a pre-defined point at which the output trigger hits a relay and turns the wipers on? Its that simple? The 5v line being hit with water wont cause an electrical short? if its that easy i'm amazed! lol
03 Acura RSX Coupe
03-28-2008, 12:30 PM
#67
Super Moderator. If my typing sucks it's probably because I'm driving....
that will kinda work maybe in a crude way, but oe rain sesors don't work by detecting the water in that way, they use a transmit & recieve eye in the windshield & it actually detects the distortion or prizm effect of rain drops on the windshield... in that way it can vary the wipers from a slow delayed stroke to a high fast speed in a heavy rain...
if you have wires that detect water I could see it not functioning anything like an oe rain sensor really...
03-28-2008, 12:33 PM
#68
I was half joking, but that's how moisture sensors in the ground work
turbocad's method is a bit more complicated but perhaps more reliable
also, no chance of short, for two reasons:
water isn't conductive enough to short 5 volts
the brain has built in overload protection
04-18-2008, 06:52 PM
#69
How about a simple voltmeter?
or a carbon monoxide detector for the interior?
Just some thoughts.
04-18-2008, 11:42 PM
#70
Just some thoughts.
The Fusion Brain is a voltmeter.
04-19-2008, 05:44 AM
#71
how about an angle sensor that can detect possible body rollovers or that can be used offroad?
Virando costas ao mundo
Orgulhosamente sós
Glória antiga, volta a nós!
04-19-2008, 10:30 AM
#72
I'm looking into this as well as a way to determine how much a machine is leaning. I've seen some single axis clinometers (sp?) but they seem to be in the $150 range.
04-19-2008, 10:59 AM
#73
you could use an accelerometer to detect hwo much G-force is in each axis
04-19-2008, 11:04 AM
#74
But I wanted to detect angles even with the car stopped
Orgulhosamente sós
04-19-2008, 01:14 PM
#75
yup, it would only work if the car was stopped...
hint: your body is experiencing a G-force of 1 g in the Y direction right now....
| Thread Tools |
| Display Modes |
Linear Mode
