Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Sensors
Old 11-22-2008, 09:56 PM   #91
Dougw133 is an unknown quantity at this point
Quote: Originally Posted by NitroLarry View Post
Haven't seen any recent posts here, but I wanted to add it would be nice to see a combo temp/humidity sensor, Phidgets already has a combo like this. Also an infrared thermometer in vehicle HVAC control. I did see this has been mentioned and there was a source problem due to costs. Would this be a possible solution: http://www.melexis.com/prodmain.aspx?sPN=MLX90614 ??
I just recently purchased a Fusion Brain and can't wait to get. Thanks for putting on the Pre-Turkey Day sale!
I second. I would be interested in Humidity.
Dougw133 is offline   Reply With Quote
Old 11-24-2008, 12:32 AM   #92
Civic Modz is on a distinguished road
Quote: Originally Posted by ginigma View Post
I picked up a couple Honeywell HIH-4000 sensors that I was going to use, but I can't get my FB board itself working after getting a new one from you guys. I think I'm just going to give up on the whole Fusion Brain project. <sigh>
A quick and easy way to get started with the Fusion Brain is to use the test software located here. With this program you can see the inputs/outputs working within minutes. You can use this to make sure your Brain, sensors and output are working correctly. When your comfortable you can then jump into using MDX.
Civic Modz is offline   Reply With Quote
Old 11-25-2008, 05:41 PM   #93
ginigma is an unknown quantity at this point
I've used the FBDemo software and it works fine. I recently got a new/repaired brain. When I hooked it up, it didn't work, so I read the forums. It looks like there was a software upgrade, so I installed the latest MDX software. That still didn't work. I used the wizard to create a new config file and that does not work. Maybe I got another bad board? Who knows. But I've decided to abandon this project. I will get a different board to use.
ginigma is offline   Reply With Quote
Old 11-25-2008, 07:04 PM   #94
If your Fusion Brain works with the FBDemo software, then your board isn't faulty. It looks like you may have another issue. From my experience, when upgrading new software I always uninstall/remove the old drivers in "Device Manager" in windows and then install the latest ones.
If you give some more detail of your problem, I'm sure the FB guys will help you ASAP.
Old 12-08-2008, 01:05 PM   #95
NitroLarry is an unknown quantity at this point
Quote: Originally Posted by greenman100 View Post
Very possible. I'll look into it! Remind me if you haven't heard back in a week or so.
Any word?
NitroLarry is offline   Reply With Quote
Old 12-08-2008, 02:00 PM   #96
Fusion Brain Creator
greenman100 is on a distinguished road
The infrared sensor will work with the FB with just 2 capacitors and a resistor, but we don't have any plans ot mass-produce kits, as it doesn't seem like there's enough demand.
greenman100 is offline   Reply With Quote
Old 10-02-2009, 09:56 AM   #97
acex008 is an unknown quantity at this point
Do you guys have account's on a home automation (or the like) forum? I am looking to use the FB on several IO's for my new house and thought before asking the questions here, I'd find out if you guys are on a different forum...
acex008 is offline   Reply With Quote
Old 10-03-2009, 12:53 PM   #98
You can try CocoonTech and there's a topic for HA on AVS.
I was going to use the FB for HA things, like temperature control and sensing when garage doors were open and automatically close them, but I had problems with the board and never really got it working, so I abandoned my projects.
Good luck.
Old 10-03-2009, 04:59 PM   #99
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
what happened with the board?
Old 10-05-2009, 09:21 PM   #100
I was never able to get the digital inputs working.
A bunch of the analog inputs were giving false readings. I was mainly using temperature sensors. Some ports would show readings that would swing tens of degrees over a few seconds. Other ports the temperature was off by a large number, e.g. room temp would be around 70, but reading would be 40-50.
I gave some other examples before. search on my username.
Old 10-05-2009, 09:26 PM   #101
2k1Toaster's Avatar
you ever do a RMA?
FS: Belkin Gold Series 10 feet, USB Type A Male to USB Type Mini-B Male Cable tf82 Classified Archive 1 06-10-2005 04:09 AM
How is this motherboard? Intel board inside.. sspiro General Hardware Discussion 5 01-16-2005 02:16 PM
Bug Reports frodobaggins FrodoPlayer 168 10-16-2004 01:25 AM
Ebay GPS (USB type) unit for sale £45 bertybassett Classified Archive 0 06-15-2004 01:11 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
