Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Sensors
Old 10-29-2007, 06:42 PM   #1
abyssdj's Avatar
abyssdj is an unknown quantity at this point
various sensors...
hi, new to the forum but i've just joined up because this fusion brain is interesting me... it MIGHT be exactly what i've been looking for.
what i need to do is take data from numerous sensors and display it on an 8" touchscreen on the dash... simple so far, however the data i need will be boost pressure, water temp, exhaust gas temp, maybe oil temp, maybe propane gas pressure, maybe cylinder head temp sensor and a few current sensors.
i noticed theres temp sensors on the fusion brain site, but im not sure they'll do what i need, and theres no boost sensors etc. i need something quite hardcore, as its going into a landrover defender that frequently takes some knocks and bangs. hardly a nice smooth ride! also, i may be able to get temp sensors with the correct thread to screw straight on in the place of the original (broken) water temp sensor, for example.
so anyway i noticed another thread on here that detailed using a 150psi sensor from dakotadigital with the fusion brain. could the other sensors from them be used? ie. 30psi boost sensor, egt sensor, etc, as they look like they may be more suitable for the job, and if so, how? if not, does anyone know of any alternatives?
also, does anyone have a direct link to download the fusion software as i'd like to have a look at it and the site wont start the download for some reason, and as im only connected on gprs at the moment its kinda slow to mess around with
thanks
abyssdj is offline   Reply With Quote
Old 10-29-2007, 07:25 PM   #2
Fusion Brain Creator
greenman100 is on a distinguished road
Just about any sensor can be used with the FB, either directly or through a resistor network.
greenman100 is offline   Reply With Quote
Old 10-29-2007, 07:31 PM   #3
abyssdj's Avatar
ok nice.. so for example, what would i need to use the dakota boost pressure sensor with fb?
Old 10-29-2007, 08:29 PM   #4
abyssdj's Avatar
another thing... how does the software work out the temperature/etc from the sensor data?
for example, i use the boost pressure sensor on dakotadigital, and my boost pressure is 1bar... how would you configure the software to display whatever voltage that is as 1bar, and how can you make sure it is accurate?
obviously the same would apply for stuff like temp sensors, etc.
Old 10-30-2007, 12:16 AM   #5
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Another resistor to create a voltage divider. The Brain only reads voltages from 0 to 5 volts. Not resistance. Most of the sensors are resistive. If the sensor outputs 0 to 12v, then a simple voltage divider again (2 resistors this time) will downscale it to 0-5v.
It works out the temperature through a formula. It parses the formula and evaluates it.
Here is a direct download link: http://www.fusioncontrolcentre.com/s...-10-07/FCC.zip
Old 10-30-2007, 07:11 AM   #6
abyssdj's Avatar
hi thanks for that when i've got a few £££ spare i'll order one and have a mess around. i figured thats how it would work out what to show on screen but thought id better check.
how would you work out the formula you need? by that i mean how do you know what the temperature (or boost, etc) should be at a given output without checking it with another gauge? i assume the sensors come with info that tells you what the output would be at a certain temperature?
for want of a simple example, if the sensor is outputting 3.5v, that may mean that the temperature is 80degrees... do you know if the dakota sensors include the info that would tell you that?
Old 10-30-2007, 01:17 PM   #7
If you email Dakota Digital, they'll tell you that stuff. If you need help converting sensor data to a formula, post with specifics once you've bought everything.
Old 10-30-2007, 03:07 PM   #8
abyssdj's Avatar
thanks, ill get in touch with them when I get chance.
how much would shipping be to england?
Old 10-30-2007, 03:10 PM   #9
about $20, the website will calculate it for you.
Old 10-30-2007, 04:35 PM   #10
abyssdj's Avatar
ok cool thanks for that
Old 10-30-2007, 07:35 PM   #11
abyssdj's Avatar
something else i wanted to check which i only just remembered about... with the digital inputs and outputs, would it be possible to control an input using my headlight stalk?
as you may or may not be able to see from my avatar, theres more than a few spotlights on my land rover which are currently controlled by two switches, offering numerous modes of operation.
to be more detailed, they can be set to all come on with main beam, just the front spots to come on with main beam, and none to come on at all. on top of that, i can also switch the roof spots on completely independent of any other lighting for wading.
what id like to do is have the same setup but controlled from the pc, as it will save me refitting the switches (i've just rebuilt it, and have not bothered with the switches yet). so what i need to know is, is it possible for the headlight stalk to control relays via the pc, and have those relays selectable and also overridable?
sorry for all the questions.. im just working out all the gimmicky goodness i can do with all this stuff
Can sensors be added to the computer? alexgray104 Input Devices 6 07-05-2007 11:51 AM
Car Alarm Sensors adaminc Hardware Development 4 03-29-2006 04:17 AM
Automotive sensors Stephan General MP3Car Discussion 0 09-20-2005 04:02 AM
temperature sensors frankz Hardware Development 23 06-14-2005 04:11 AM
Need help finding idle and temp sensors wizardPC Off Topic 0 05-07-2002 12:40 AM
