Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Sensors
Old 11-22-2007, 08:55 AM   #1
h3rk will become famous soon enough
Thermometer - Range/Accuracy/Direct Contact?
I think somewhere buried in one of these threads is my answer. I think I know which one, but I can't seem to find it there either.
So:
What is the min/max range of your thermometers?
What is the accuracy?
Will I physically be able to get a direct-contact, metal temp reading with it?
h3rk is offline   Reply With Quote
Old 11-22-2007, 10:04 PM   #2
Fusion Brain Creator
greenman100 is on a distinguished road
MCP9700. They're good for -40C to 125C, with accuracy of about 2C. I've taken them to high emperatures than 25 and they seem accurate, but we don't guarantee that.
Yes, direct contact is fine, just superglue or epoxy or clamp it on.
greenman100 is offline   Reply With Quote
Old 02-16-2008, 03:33 PM   #3
ginigma is an unknown quantity at this point
I currently have 3 temp sensors connected, and they all have the same reading of 67.209 degrees. They are in different parts of my house, so I would expect different readings.
I placed a temperature/humidity data logger next to one of them, and that reported a temp of 64.1 degrees, so at least one temp sensor is off by a significant amount.
Thoughts?
ginigma is offline   Reply With Quote
Old 02-17-2008, 07:02 PM   #4
The temperature sensors are rated to +/- about 2C, which is +/- 4deg F.
Additionally, your house is probably pretty similar in temperature, most parts of a house are within 1 degree of each other.
The Fusion Brain is not designed to be a precision measurement device.... Most precision temperature sensors cost several hundred dollars.
You could improve accuracy with an op-amp to amplify the temp sensor's signal, but that would reduce it's effective range.
Old 02-19-2008, 03:11 PM   #5
After seeing AtomicMonkey's issues here, I decided to look more into the issue.
As it turns out, some of the ADC (analog to digital converter) values are not set uniformly from the factory. They are stored in registers that can have different default values depending on the manufacturer. This caused small errors in some boards, perhaps including yours, and large errors in recent boards (Shipped mid-January and later).
I have recoded the relevant parts of the firmware, and have the following:
As you can see, I hooked up a ton of temperature sensors, 12 at first:
Displayed are the raw voltages. Converted, they are as follows:
Code:
Raw Volts deg F 0.879765 76.286 0.869990 75.38369231 0.879765 76.286 0.889541 77.1884 0.889541 77.1884 0.874878 75.83489231 0.874878 75.83489231 0.899316 78.09070769 0.889541 77.1884 0.889541 77.1884
And then, to address AtomicMonkey's problem, here is a picture of 9 thermometers and one variable resistor set at ~3.95vDC.
If you are affected by this, we offer two options, both of which can be arranged over our email account:
1.) Buy a new PIC from us. $12 shipped.
2.) Exchange PICs. Send us $6, and we will send you a new PIC. Once we get your old PIC back, we refund you.
3.) Send back your PIC, and we'll send you a new one.
All orders shipped on or after 2/19/2008 will not have this problem.
Old 04-09-2009, 07:54 AM   #6
baillie11 is an unknown quantity at this point
wrong temperature being displayed
Hi I just got a temp sensor from you and then followed your tutorial on Youtube (
Fusion Brain --MDX-- Help with Analog Input Labels
You need to upgrade your Flash Player
When I start it up I get a Voltage of 1.0 and a current temp of 34 (celsius - im in australia).
This sensor is inside my house and sitting next to a digital thermometer that is currently showing 22.9.
what am I doing wrong?
PS I did NOT add the farenheit conversion to my confige as it is not needed.
PPS I am using a Version 3 Brain
baillie11 is offline   Reply With Quote
Old 04-09-2009, 10:03 AM   #7
Does the value change with temperature?
Can you upload a picture of how you have it connected?
Old 04-09-2009, 11:52 AM   #8
Here is a picture, its rather blurry but the best I can get with my camera phone.
The temperature has changed (its currently reading 33.5 Deg Celsius) but the Voltage has remained the same at 1.0.
Cheers
Old 04-09-2009, 12:36 PM   #9
Picture's not loading for me here.
Can you heat/cool the probe (with ice, or something warm) and let me know what happens?
Old 04-11-2009, 10:39 PM   #10
I have heated it and the temperature does change.
I have tried attaching a link to the photo again.
<a href="http://s441.photobucket.com/albums/qq138/pokersoft/?action=view&current=FusionBrain.jpg" target="_blank"><img src="http://i441.photobucket.com/albums/qq138/pokersoft/FusionBrain.jpg" border="0" alt="Photobucket"></a>
Old 04-12-2009, 03:21 PM   #11
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
This is the link you want:
Old 04-12-2009, 03:26 PM   #12
2k1Toaster's Avatar
Cheers
1.0v is 30.7 C
So the voltage should not be 1.0 if you are reading 33.5. Which tells me either you dont have it connected to the correct port, your multimeter is off, or you didnt post the correct voltage value.
Bring up a virtual brain and see what values you get. Easiest way to determine if you connected it to the right port.
Release new phoco integration preview Robby BMW Road Runner 544 09-12-2009 06:29 AM
looking for contact info for tview whosurpopi General Hardware Discussion 1 01-25-2007 10:33 PM
eedesignkits.. contact details?.. catboy General Hardware Discussion 0 12-05-2006 03:57 AM
Contact Armen argetim LCD/Display 17 03-23-2005 06:05 PM
LCD 4x40 contact points melted away? Lakers0340 General Hardware Discussion 1 04-22-2000 12:48 AM
