Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Sensors
Old 12-10-2007, 12:59 PM   #1
h3rk will become famous soon enough
Current Sensor
Is your current sensor an in-line design? Or is it inductive (do I put the sensed wire under that chip)?
If it's 'in-line'? what kind of terminals is it set up for, I can't quite tell from the pic how to connect.
h3rk is offline   Reply With Quote
Old 12-10-2007, 01:50 PM   #2
Fusion Brain Creator
greenman100 is on a distinguished road
inline, solder wires to the PCB. The holes in the PCB are sized to handle about a #14 wire.
greenman100 is offline   Reply With Quote
Old 12-10-2007, 02:03 PM   #3
hmmm, how would one safely approach an install where 30-40Amps was expected (obviously, 14AWG is too small to handle that). Do you think a one inch long lead with a spade would be ok for that situation? Or should I go with a different, expensive inductive sensor?
Old 12-10-2007, 09:38 PM   #4
mike938 is an unknown quantity at this point
I was wondering this as well. I was planning on ordering 2-4 of them in order to measure the current draw of my amp(s) using 2 per amp in parallel in so the limit would be 100A in case it hits over 50A drawn. I'd be using 4ga wiring which obviously wouldn't fit in the hole if it's designed for 14ga?
mike938 is offline   Reply With Quote
Old 12-10-2007, 11:37 PM   #5
You can't use two in parallel, that's for sure.
The sensor can handle 50A, maximum. It's a good idea to keep the sustained current around 25A. 14 gauge wire is fine for that, and 12 gauge might fit in the hole.
In future revision of the sensor, we will make the hole and traces bigger.
Old 12-10-2007, 11:53 PM   #6
Okay, my thinking was running the 2 in parallel would split the current in half and then just re-add the values in software.
................../-sensor--\
Wire --------...............------------wire
..................\-sensor--/
Old 12-11-2007, 12:25 AM   #7
the trouble is, the current won't split evenly. it'll overload a sensor.
Old 12-11-2007, 12:32 AM   #8
ah ok. thanks for clearing that up
HD Radio Commands MGD Road Runner 8 07-23-2009 04:01 PM
New OBDII scantool - Beta testers? tmort Engine Management, OBD-II, Engine Diagnostics, etc. 173 01-08-2008 07:44 PM
RRSkinEditor BUGS / FIXES / COMMENTS / CURRENT PROGRESS OUTDATED pRoFiT RR Skins 231 10-26-2007 05:41 PM
Current draw when PC is off/in hibernation. Arathranar Power Supplies 14 01-25-2005 04:21 PM
Suggestions for current for a USB relay controller... Zac General Hardware Discussion 2 05-28-2004 12:52 AM
