Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Sensors
Old 04-02-2008, 12:43 PM   #1
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
photosensor doesnt appear to respond to light level
Here's another question to bug you guys with.. i received my photosensor today and hooked it up to the brain per instructions (red facing the inside of the board). Using a dummy skin i tested the results. No matter if the sensor is in ambient light or in total darkness all it continues to do is jump between two numbers... 0.796 and 0.801. I checked the skin to make sure its reading from the correct port, i've changed ports, i've tried adding the formula ( ($p$/0.016)|p=VINC[!] ) to the #SETTINGS# section but nothing seems to make a difference. What should i check next?
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 04-02-2008, 12:52 PM   #2
Fusion Brain Creator
greenman100 is on a distinguished road
Try flipping the connector around and report back.
greenman100 is offline   Reply With Quote
Old 04-02-2008, 12:58 PM   #3
Terminal flasher
nope didnt not make a difference.. i unplugged the unit switched the connector but its doing the same thing. Here's my section for the sensor input:
Code:
#STARTNEW# #NAME#photo #TYPE#PHOTOELECTRIC #SETTINGS#($p$/0.016)|p=VINC[!] #SUFFIX#uW/cm^2 #PREFIX# #SETTINGS# #DECIMALS#9 #VIDPID#USB\VID_04D8&PID_000C\6&42FFB0A&0&2 #SIZE#105,94 #LOCATION#200,0 #SHOWTEXT#true #TXTCOLOUR#LightGray #PAGE#0 #PORT#0 #BORDERSIZE#0 #PLOTLENGTH#100 #ENDNEW#
03 Acura RSX Coupe
Old 04-02-2008, 01:03 PM   #4
that's wild. did you try it on multiple inputs? what's it report in the debug window?
there's a chance the sensor is busted, if thats the case, we'll happily replace it
Old 04-02-2008, 01:18 PM   #5
Terminal flasher
how do i enable a debug window.. i'm simply using the 2.0 software with a hacked up version of the default skin. just moved it to another port and the number change but still dont reflect it knows a difference between dark and light
03 Acura RSX Coupe
Old 04-02-2008, 01:20 PM   #6
it's acting like an open circuit, or you're reading the wrong port.
debug window:
click just under the title bar
hold crtl, shift, alt, and type "DEBUG"
type "open raw debug" in the new window
screenshot the debug window
Old 04-02-2008, 02:05 PM   #7
Terminal flasher
debug window:
ok here's the screenshot
i looked at the board again to make sure i have the right port and its plugged into a6 but i understand how u mean that it looks like its an open circuit because if i change the temp sensor to the incorrect port i get the same type behavior.
03 Acura RSX Coupe
Old 04-02-2008, 02:16 PM   #8
yeah, it's acting like an open circuit. busted sensor.
you can look for a broken connection somewhere if you want, or we can send a new one. email us your address.
Old 04-02-2008, 02:21 PM   #9
Terminal flasher
i tested the voltage at the 5v metal pin on the sensor end and its receiving power, there must be something wrong within the small plastic casing. If its ok what i'll do is create a new order for the extensions and stuff i planned on purchasing today, and in the notation reference this thread. That way you guys can just ship the new sensor with the rest of my order.
03 Acura RSX Coupe
Old 04-02-2008, 02:36 PM   #10
perfect
Old 04-02-2008, 02:51 PM   #11
Terminal flasher
perfect
ok i placed the order. I originally attempted to do the payment via paypal (not express) but it added $5.00 shipping to the price with shipping.. so i cancelled that and just paid via paypal express which worked fine. That might be something of a problem for someone else downt he road though.
03 Acura RSX Coupe
FAQ: LCD Technologies dontpntpool LCD/Display 4 03-15-2007 01:20 AM
how many post whores does it take to change a lightbulb? TyBong Off Topic 22 01-05-2006 09:26 PM
How many does it take veedubya Off Topic 11 06-03-2005 01:15 PM
Gamma control by light sensor kronos General Hardware Discussion 28 03-14-2005 08:57 AM
How Many Does It Take... mp3z24 Off Topic 8 09-19-2004 11:54 PM
