Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Sensors
Old 04-24-2008, 04:23 PM   #1
Fusion Brain Creator
greenman100 is on a distinguished road
Accelerometer and Noise Filtering (Moving Average Example)
Often times, in data collection, the raw data is rather noisy. In the figure below, I have connected all 3 axes of our accelerometer to our board, and set the board to log every 100mS.
I then moved the accelerometer through a serious of orientations, such that acceleration due to gravity (1 G) was sensed on each of the axes. As you can see, the resulting data was quite noisy.
However, we can apply a moving average to the data inside the MDX software as follows:
Code:
<iochannel id="Port9" port="9" brain="TestBrain1" type="analogue_input"> <options history="10" auto_average="true"></options> </iochannel>
Note the options history and auto average. Options history specifies how many of the past parameters to hold in memory when performing the averaging calculation. For example, in this case:
Value _new = (Value1 + Value2 + Value3 + Value4 + Value5 + Value6 + Value7 + Value8 + Value9 + Value10) / 10
where values 1-10 are the past 10 measured values, respectively.
Then, the accelerometer is put through a range of motions, as shown below:
The units are 100mS and G-force.
Hope this helps! Post any questions.
greenman100 is offline   Reply With Quote
Old 05-12-2008, 02:52 PM   #2
FLAC is for flaccid
parksgm's Avatar
parksgm will become famous soon enough
Great post...thanks for the tips!
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
