Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Sensors
Old 05-25-2008, 12:32 PM   #1
mx270a's Avatar
mx270a is on a distinguished road
Tilt angle sensor
I purchased a Clinometer to measure the tilt angle of something. Thought I'd post some details for anyone looking for something similar.
Part number 824-02110002, MSI Sensors, Clinometer, Single Axis, Vertical mount. Price of $137 plus shipping.
This particular sensor is good to 60 degrees either side of center. It has no moving parts, but does contain a fluid which is what is used to determine angle. Unfortunately, that also causes a "slosh" effect while bouncing, so I did have to add some averaging to get it to move smoothly.
This sensor is ratiometric, so you give it 5 volts, and it will output 2.5 volts when level. Output voltage goes up or down based on which way it is tilted.
Mouser Electronics Part
Data Sheet
mx270a is offline   Reply With Quote
Old 05-26-2008, 12:08 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
nice
Old 08-04-2008, 08:10 PM   #3
thwack's Avatar
thwack is on a distinguished road
Also take a look at www.leveldevelopments.com they have a dual axis inclinometer that runs 5v interface similar to that described above. Would be great for anyone with a 4wd interested in seeing the side slope angle or angle on inclinatio going down or up a hill.
Car PC -Jetway J7F2WE2G, 4Gb CF Boot, 32Gb CF Data, 1Gb Ram, M2-ATX PS, 8" 800x600 TS, SiLabs USB Radio, Garmin GPS15L, Ublox SBR-LS DR GPS, Fusion Brain, Multibay Card Reader, Panasonic Slotload DVD+-RW, Custom Fab Steel Case
Car- 1988 Nissan Patrol 4WD
thwack is offline   Reply With Quote
Old 03-02-2009, 11:48 PM   #4
Nd4SpdSe is an unknown quantity at this point
Hey, I've been looking for something like this for my Xterra. I don't have a nice spot for analog gauges, but I have my LCD in that spot.
What would you use for software interface and to display the date?
Nd4SpdSe is offline   Reply With Quote
VisionTouch 10.4" High Resolution , Incredible viewing angle screen. hailrazer LCD/Display 6 05-13-2009 08:21 PM
New OBDII scantool - Beta testers? tmort Engine Management, OBD-II, Engine Diagnostics, etc. 173 01-08-2008 07:44 PM
Mass Air Flow Sensor h3rk FB Sensors 5 12-16-2007 04:15 PM
Relocating Portable DVD Remote Sensor... AEFL92 General Hardware Discussion 1 09-10-2007 04:03 PM
Silly question (probably any HS student could figure) inspired by some other post h3rk Off Topic 10 03-19-2007 05:45 PM
