Quote: Originally Posted by djurchicprelude
Can the Thermometer sensor just act as a temperature sensor is mounted outside the car?? And used in RR to display the readings? Thanks
Yes and yes... i have a temp sensor that is sitting underneath thes pare tire in my car. I drilled thru the metal and epoxied the sensor and it still gets fairly accurate readings. RR can display the data via RRFusion or MDX's COM link.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
