Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Sensors
Old 01-15-2009, 12:20 PM   #1
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
water sensor
Hey guys,
I'm toying around with the idea of having a computer controlled ballast system in my boat. I want this to be fully automatic and therefor would need a way to tell the computer when the tanks are full and to stop pumping. I think that tapping into the overflow would be the easiest way to 'sense' when the tanks are full. Basically.. when they tanks fill up, they'll start evacuating the flowing water out of the overflow port. if i could put something there that could sense the water then it could tell fb to shut down the pumps.
does anyone know of sensor that would fit my needs?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 01-15-2009, 12:33 PM   #2
Fusion Brain Creator
greenman100 is on a distinguished road
2 contacts and a darlington pair
ala here:
http://www.zen22142.zen.co.uk/Circui...waterrelay.htm
greenman100 is offline   Reply With Quote
Old 01-15-2009, 12:45 PM   #3
MySQL Error
scott_fx's Avatar
that is perfect... thanks!
M10k
My Car Pc Install
Old 01-15-2009, 12:51 PM   #4
MySQL Error
scott_fx's Avatar
just a thought since i have some of these ic's laying around but, could you also use a qprox capacitance switch to sense water?
M10k
My Car Pc Install
Old 01-15-2009, 01:00 PM   #5
i guess but a darlington pair is like 20 cents
Old 01-15-2009, 01:02 PM   #6
MySQL Error
scott_fx's Avatar
fair enough
M10k
My Car Pc Install
Old 01-15-2009, 01:22 PM   #7
yeah, the problem is that you'll encounter some issues with residual moisture being enough to trigger the circuit.
really you probably want a cheap flowmeter like this, with a LED/phototransistor
http://cgi.ebay.com/Rate-Meter-Serie...3A1%7C294%3A50
Old 01-15-2009, 01:25 PM   #8
MySQL Error
scott_fx's Avatar
i wonder if that would hinder the flow of water though.
M10k
My Car Pc Install
Custom USB Parking Sensor interface (formally PDC-USB) Robby BMW Hardware Development 325 Yesterday 05:52 PM
New OBDII scantool - Beta testers? tmort Engine Management, OBD-II, Engine Diagnostics, etc. 173 01-08-2008 07:44 PM
Mass Air Flow Sensor h3rk FB Sensors 5 12-16-2007 04:15 PM
Relocating Portable DVD Remote Sensor... AEFL92 General Hardware Discussion 1 09-10-2007 04:03 PM
FS-PC Water Cooling Gear, Hard drives Misc Stuff belezeebub Classified Archive 4 04-12-2006 05:55 PM
