Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Sensors
Old 02-07-2009, 05:45 PM   #1
FredWorrell is an unknown quantity at this point
Freescale Pressure Sensors
I don't know if these pressure sensors have been discussed. They are the Freescale series of pressure sensors (MPXHZ6130A as an example). They have three wires, +5 V, Ground, and signal. The signal is 0-4.8 VDC. This makes them a PERFECT sensor for the Fusion Brain. The one I am going to use is an absolute pressure 2.5 bar model. They are very accurate. It has a barbed fitting so it is easy to plumb. It will tolerate temperatures up to 125 Degrees C so it can sit under the hood (or cowling in my case). They have a bunch of models with various ranges. They have Psig and differential pressure types too. The best part is they are pretty cheap, around $12.
http://www.freescale.com
FredWorrell is offline   Reply With Quote
Old 02-08-2009, 12:36 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Good find
Old 02-13-2009, 02:20 PM   #3
wrxyboy is an unknown quantity at this point
will these be capable of using on a air ride setup.
wrxyboy is offline   Reply With Quote
Old 02-13-2009, 05:17 PM   #4
Freescale
Air Ride? Only you know your system, only you will know if they will work. If they have the correct range and type then you can use them. They are designed for automotive use, mostly for measuring turbo boost. They measure pressure, you choose what to use them for.
I am going to use them for coolant pressure and boost. Whatever you use them for they are perfect for input to the fusion brain.
Custom USB tyre pressure monitoring interface Robby BMW Portal Media Car PC Gadgets and Accessories 1070 Yesterday 01:51 AM
New OBDII scantool - Beta testers? tmort Engine Management, OBD-II, Engine Diagnostics, etc. 173 01-08-2008 07:44 PM
Backup Sensors? Shredder General Hardware Discussion 0 11-09-2007 01:31 PM
various sensors... abyssdj FB Sensors 10 10-30-2007 07:35 PM
Pc integration for Smartire pressure system or Back up sensors Kamakazie2 Hardware Development 13 02-17-2006 07:13 PM
