Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Sensors
Old 03-21-2009, 10:13 PM   #1
raleigh_henshaw is an unknown quantity at this point
Where to buy sensors?
I need to by the following 5v sensors for automotive use:
Temp sensor (for oil and coolant)
Pressure (for oil pressure)
Air Flow Temp. (I don't think a regular temp sensor will work?)
Vacuum/pressure sensor
Any help on where to find these would be great. Obviously I could go and start ordering for parts stores but I need to have the output reference chart to convert the raw voltage to a value. Any help would be great.
raleigh_henshaw is offline   Reply With Quote
Old 03-21-2009, 11:19 PM   #2
Sorry, I found them
I ended up finding them on Summit Racing's site. They call them "senders" and are designed for aftermarket gauges. Will work great for what I want to do.
Anybody have some working gauges or sample skins I could start with. I'm really new at this and need some direction.
Old 03-23-2009, 07:43 PM   #3
FredWorrell is an unknown quantity at this point
I would get the vacuum/pressure sensors from Freescale. See the other postings on the subject.
Oil Temp sensor - a standard sensor from Summit Racing. The sensors are not linear, the temperature is proportional to the natural log of the resistance change.
I don't know what an air flow temp sensor is (air flow? Temperature?) You can use differential pressure on the inches of water scale and convert to to a flow signal, but it is not a direct conversion. Flow is proportional to the square root of the differential pressure.
A square root function and natural log function would be great additions to the configurator (hint hint).
FredWorrell is offline   Reply With Quote
Backup Sensors? Shredder General Hardware Discussion 0 11-09-2007 01:31 PM
various sensors... abyssdj FB Sensors 10 10-30-2007 07:35 PM
Anywhere in UK to buy a carnetix? mp3oplecarrier Power Supplies 22 01-06-2005 09:29 AM
Where to buy seiko L4034 Adam F LCD/Display 6 12-27-2001 12:21 AM
