I have been working very hard the past couple weeks between jobs and school and have come up with this.
It is the beginning to a new configuration utility for the Fusion Brain. It will be fully compatible with Uber MDX Edition, which will be released within the month I hope. It is almost fully backwards compatible with Uber XNA.
Right now I am just looking for some feedback, good or bad. What you like, or dislike. What you want to see added, or what you feel is not neccessary. Currently programming is going along at a painfully slow pace. If there is anything I have learned from the Skin Designer of Version 2, it is that most people do not think like me! People do not see what I see, and therefore cause errors by doing things the program wasnt able to handle.
In this version, I am trying to really protect it. Therefore, please
try to break the program!!! I think that everything that is functional now is fairly well secured. Everything is mostly double verified (once leaving/saving the info and another time when parsing it back into the global lists). So please try to make it error. And by error I mean "An exception has occurred, please click here to close the program and send the report to microsoft" or something of the sort. Something that kills the program.
Please report back anything you find here.
Creating, Opening and Saving of files is working. Logic is working. Graphics are working. Just need to update the help sections, and add font and text as well as multi-images and rotate-images. Then it will be done! mwahahahahaha.
If you currently own a Fusion Brain, I urge you to try the Auto Search feature in the Fusion Brain adding menu. I have tried to make it more compatible.
Also you should see lots of help buttons. Well they dont work.... yet. I have to still write the documentation. But having a bunch of lonely buttons will make me more inclined to do so.
So to sum up, please let me know your thoughts or concerns about this, as well as any errors you encounter. You should only need the exe, and the 2 communication dll's (same as for Version 2 software and above).
I have included a screenshot below of what you should see when you open it.
Download (Last Update - 23/05/2008 @ 2:15am MST): http://www.fusioncontrolcentre.com/M...nfigurator.exe
