Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 02-21-2008, 03:49 AM   #1
customaudioman's Avatar
customaudioman is on a distinguished road
configure the new mdx 3.0.0.0
when I open the mdx configuration how and where do I add my variables for the steering wheel controls. Like the voltage is between 3.39 - 3.97 for the mode button. vol up button is 1.0- 1.08 and so on. Do i add them in the at the fusion configuration xml document, under logic? It doesnt give me ''statements'' and then the ''if'' like in the old program. Just logic and then all ''logging'' and all ''variables'' Also when I open the mdx configuration I cant open configurations that I saved when I closed the program. When I click on the folder icon above thats says ''open a configuration file'' it does nothing. It like I start back over again every time I open the program, it tells me to add the brain and analog input
customaudioman is offline   Reply With Quote
Old 02-21-2008, 03:53 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
This is why I havent released MDX. The configurator is like 20% to 30% done. The main program is fully functional. Use Notepad or any XML document editor with the code provided in your other thread, and save it.
You cannot open, because there is no open function implemented.
And what you want to do is in the logic section of the configurator which I am only programming right now. (just updated the config thread).
I posted the link just to help you out and get you a more stable, easier program that worked while the configurator was being programmed. Once it is released, both will be functional and included in a single installer.
Old 02-21-2008, 03:55 AM   #3
2k1Toaster's Avatar
I should add, if you do actually encounter an error with the configurator, please post in the configurator thread: http://www.mp3car.com/vbulletin/soft...a-testing.html
That way we can consolidate everything.
So far there have been no errors, so it is looking good so far.
Uber MDX Configurator Beta Testing... 2k1Toaster FB Software 344 06-09-2008 12:49 AM
Configure StreetDeck to use Multiple GPS devices CraziFuzzy Wiki Discussion Threads 2 10-21-2007 10:56 AM
Configure Dlink Radio vicky_obee Road Runner 1 10-03-2007 06:23 PM
How to configure MapMonkey in CF 1.6b like ext. app? tempi Centrafuse 3 04-16-2006 03:29 PM
Best frontend with shortcut to configure with remote controls laser1983 Newbie 0 04-05-2005 10:19 PM
