Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 03-22-2008, 11:08 PM   #1
scotty562 is on a distinguished road
Integrate fusion brain commands into road runner buttons
I don't really want to integrate an entire fusion brain skin into road runner. I just want to integrate some of the fusion brain buttons into the road runner skin file I already use. For instance I'm going to take the road runner button that currently says phone and rename it to "Garage." Then I'd like the road runner button "Garage" to activate the fusion brain button that triggers the relay that the garage door opener is hooked up to.
Another thing I'd like to do is integrate the inside and outside temp onto the main menu of my road runner skin.
Is something like this doable without using the entire fusion brain skin?
2001 SS Camaro carputer
scotty562 is offline   Reply With Quote
Old 03-22-2008, 11:14 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Not currently.
Since last October or November, I have been trying to get a COM object working for it to be possible. Its March now and it is still not working. I am working on it though.
I pretty much have RoadRunner working for COM in XP and Vista. StreetDeck doesnt work though. And with RoadRunner there are some issues. When it is released, MDX will need to run in the system tray to interpret the COM commands.
Old 03-22-2008, 11:37 PM   #3
That's good enough for me. I'll be looking forward to this feature until then .
Old 03-23-2008, 08:28 AM   #4
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
does the MDX beta allow the COM object or will that have to wait til final release?
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 03-23-2008, 07:52 PM   #5
2k1Toaster's Avatar
The COM object is not in any of the available software now. When it works, it will go in MDX, and it will just require a new EXE and a dll to be downloaded.
Old 04-13-2008, 09:11 PM   #6
norwegianguy's Avatar
norwegianguy is an unknown quantity at this point
how far along?
just wondering how far along the com object is?
is it partially working or not at all?
norwegianguy is offline   Reply With Quote
Old 04-13-2008, 11:10 PM   #7
greenman100 is on a distinguished road
just a search away...
http://www.mp3car.com/vbulletin/1200662-post4.html
greenman100 is offline   Reply With Quote
Old 07-18-2008, 05:52 AM   #8
Dougw133 is an unknown quantity at this point
Scotty how are you doing the garage door opener? I wanted to do this myself. Just a simple relay? Could you post a quick how to? Thanks...
Dougw133 is offline   Reply With Quote
Old 07-18-2008, 08:25 AM   #9
Yeah. It's a simple relay. A really friggin cool relay .
1. Tear garage door opener apart
2. Find the two metal pieces you need to short to make the garge door open
3. Solder really small wires too each one of these and then touch the tips of the wires together and make sure they open the garage door
4. Hook these two wires up to a relay
5. Program the brain to trigger the relay
6. Life is good
I'll actually use this once I can make a road runner button do this. Just a matter of time till that function is ready.
Old 07-18-2008, 08:41 AM   #10
Terminal flasher
RRFusion is an working option to get fusion brain digital out controls into rr commands. Search for it.
03 Acura RSX Coupe
Old 07-18-2008, 08:59 AM   #11
Can I use my existing skin with this? I just want to rename one of my rr buttons and have it execute the code that opens my garage door. An example or something would be nice. I'll look through your thread when I get off work.
Old 07-18-2008, 09:17 AM   #12
Terminal flasher
yes you can use whatever skin you would like.. you would just need to modify commands on the skin. So you install RRFusion. And lets say open is port 0 on your FB and close is port 1, simply assign two buttons commands. First button is DIGITALOUT0TOGGLE and second button is DIGITALOUT1TOGGLE. Real easy
03 Acura RSX Coupe
Old 07-18-2008, 09:30 AM   #13
Wow that is really simple. Thanks for putting that together .
Old 07-18-2008, 10:04 AM   #14
Terminal flasher
it was needed.. i will be expanding in the future as well. I'll implement timed events on the digital output commands soon. So you could put DIGITALOUT0ON;10 as a command. Using that command, the output would toggle ON for 10 seconds then turn itself off. a little logic never hurt nobody
03 Acura RSX Coupe
Old 09-22-2008, 01:24 AM   #15
djurchicprelude is on a distinguished road
would it have to be two diffrent buttons in rr? how would u use two relays then? wouldnt it be just one button and one relay and the same command, "garage" for instance would do both open and close the gargage because the relay would only have to work for a second or so?? just like the restart button on carpc's. sorry i probably worded that horribly. i dont know how else to say it? hope u understand what i mean
djurchicprelude is offline   Reply With Quote
Road Runner Installation Program bry21317 Road Runner 88 01-29-2008 10:22 PM
Road Runner Shell Issue B|ade Road Runner 4 05-24-2007 06:00 AM
Multiple screens with Road Runner Billious Road Runner 6 04-04-2007 02:59 PM
road runner freezing on startup :( skiman Road Runner 6 03-13-2007 10:37 AM
Road Runner Resolution setting JohnWPB Road Runner 3 03-01-2007 11:02 AM
