Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 03-28-2008, 02:30 PM   #1
dhantiflag's Avatar
dhantiflag is an unknown quantity at this point
Problem With sending Winamp commands
ok, so i was working on steering wheel controls working
got all my Volt #'s from the car had it all setup like i thought but nothing actually happens
now the label displays the correct volts
but doesnt display as a decimal, it shows like 4897
Code:
<?xml version="1.0" encoding="utf-8" ?> <FusionControlCentreConfiguration version="1.0.0.0" author="Kevin Holy" date_created="Tuesday, March 25, 2008 at 10:19:44 PM" last_modified="Tuesday, March 25, 2008 at 11:26:01 PM"> <require> <!-- Begin Function Instances --> <font name="LED50" originalSize="50" font_config="Content\config\fonts\FusionFontLED.xml"></font> <!-- End Function Instances --> </require> <graphics> <!-- Begin Global Graphic Settings --> <main_display designed_for_size="800,600" show_at_size="800,600" menubar="Sizeable" RunInSystemTray="False" MinimizeToSystemTray="True"></main_display> <text_label id="Volt Monitor" text="00" auto_monitor="analogue input" auto_monitorTarget="Steering_Wheel_Control"> <font font_id="LED50" font_size="35"></font> <display location="165,165" page="0"></display> <config decimals="3" max_size="70,40"></config> </text_label> <!-- End Global Graphic Settings --> </graphics> <io> <!-- Begin Fusion Brain Instances --> <brain id="Holy's Brain">USB\VID_04D8&amp;PID_000C\5&amp;13735D69&amp;0&amp;2</brain> <!-- End Fusion Brain Instances --> <!-- Begin Timer Setup --> <timer id="input" interval="75"></timer> <timer id="output" interval="100"></timer> <timer id="gui" interval="50"></timer> <timer id="logic" interval="50"></timer> <!-- End Timer Setup --> <!-- Begin Digital Output Instances --> <!-- End Digital Output Instances --> <!-- Begin Analogue Input Instances --> <iochannel id="Steering_Wheel_Control" port="0" brain="Holy's Brain" type="analogue_input"> <options history="0" auto_average="false"></options> </iochannel> <!-- End Analogue Input Instances --> </io> <logic> <!-- Begin Logging Setup --> <all_logging> </all_logging> <!-- End Logging Setup --> <!-- Begin Variable Declarations --> <all_variables> </all_variables> <!-- End Variable Declarations --> <!-- Begin Logic Declarations --> <all_statements> <if fire_on="logic"> <boolean_operation type="and"> <parameter1> <boolean_operation type="greater than or equal to"> <parameter1> <analogue id="Steering_Wheel_Control" time="0"></analogue> </parameter1> <parameter2> <number>1.6</number> </parameter2> </boolean_operation> </parameter1> <parameter2> <boolean_operation type="less than or equal to"> <parameter1> <analogue id="Steering_Wheel_Control" time="0"></analogue> </parameter1> <parameter2> <number>1.8</number> </parameter2> </boolean_operation> </parameter2> </boolean_operation> <then> <do function="send key" functionTargetID="winamp" vote_opinion="Up Arrow" vote_priority="medium"></do> </then> </if> <if fire_on="logic"> <boolean_operation type="and"> <parameter1> <boolean_operation type="greater than or equal to"> <parameter1> <analogue id="Steering_Wheel_Control" time="0"></analogue> </parameter1> <parameter2> <number>0.5</number> </parameter2> </boolean_operation> </parameter1> <parameter2> <boolean_operation type="less than or equal to"> <parameter1> <analogue id="Steering_Wheel_Control" time="0"></analogue> </parameter1> <parameter2> <number>0.7</number> </parameter2> </boolean_operation> </parameter2> </boolean_operation> <then> <do function="send key" functionTargetID="winamp" vote_opinion="Down Arrow" vote_priority="medium"></do> </then> </if> <if fire_on="logic"> <boolean_operation type="and"> <parameter1> <boolean_operation type="greater than or equal to"> <parameter1> <analogue id="Steering_Wheel_Control" time="0"></analogue> </parameter1> <parameter2> <number>2.55</number> </parameter2> </boolean_operation> </parameter1> <parameter2> <boolean_operation type="less than or equal to"> <parameter1> <analogue id="Steering_Wheel_Control" time="0"></analogue> </parameter1> <parameter2> <number>2.8</number> </parameter2> </boolean_operation> </parameter2> </boolean_operation> <then> <do function="send key" functionTargetID="winamp" vote_opinion="Z" vote_priority="medium"></do> </then> </if> <if fire_on="logic"> <boolean_operation type="and"> <parameter1> <boolean_operation type="greater than or equal to"> <parameter1> <analogue id="Steering_Wheel_Control" time="0"></analogue> </parameter1> <parameter2> <number>3.5</number> </parameter2> </boolean_operation> </parameter1> <parameter2> <boolean_operation type="less than or equal to"> <parameter1> <analogue id="Steering_Wheel_Control" time="0"></analogue> </parameter1> <parameter2> <number>3.75</number> </parameter2> </boolean_operation> </parameter2> </boolean_operation> <then> <do function="send key" functionTargetID="winamp" vote_opinion="B" vote_priority="medium"></do> </then> </if> <if fire_on="logic"> <boolean_operation type="and"> <parameter1> <boolean_operation type="greater than or equal to"> <parameter1> <analogue id="Steering_Wheel_Control" time="0"></analogue> </parameter1> <parameter2> <number>4.2</number> </parameter2> </boolean_operation> </parameter1> <parameter2> <boolean_operation type="less than or equal to"> <parameter1> <analogue id="Steering_Wheel_Control" time="0"></analogue> </parameter1> <parameter2> <number>4.9</number> </parameter2> </boolean_operation> </parameter2> </boolean_operation> <then> <do function="send key" functionTargetID="winamp" vote_opinion="C" vote_priority="medium"></do> </then> </if> </all_statements> <!-- End Logic Declarations --> </logic> </FusionControlCentreConfiguration>
if someone could take a look at let me know why nothing happens
thanks!
dhantiflag is offline   Reply With Quote
Old 03-28-2008, 05:26 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
"down arrow" --> "DOWN"
"up arrow" --> "UP"
and for future reference:
"left arrow" --> "LEFT"
"right arrow" --> "RIGHT"
Also if using 0 as your time tag for the analogue input, you need the latest version of MDX from the 26th of March: http://www.fusioncontrolcentre.com/T...26-03-2008.rar
Old 03-28-2008, 06:19 PM   #3
greenman100 is on a distinguished road
nick - you sure? left and right have different syntax?
greenman100 is offline   Reply With Quote
Old 03-29-2008, 12:06 AM   #4
2k1Toaster's Avatar
nope.
Made a boo-boo. Fixed it.
The craziest USB soundcard problem ever Sibi General Hardware Discussion 6 03-07-2008 10:25 AM
Not your typical flicker problem JPuma LCD/Display 17 05-30-2007 10:28 AM
Problem also with MM commands in RR skin Alx0363 RR Bug Tracker 9 04-02-2006 03:19 AM
had an all day (9 hr) problem at work.... wizardPC Off Topic 13 10-20-2005 12:50 PM
winamp start up problem jett98 Software & Software Development 6 10-21-2002 05:18 PM
