Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 04-06-2008, 04:09 PM   #1
mx270a's Avatar
mx270a is on a distinguished road
Sample VB application to control a Fusion Brain
I've seen a few people here asking how to control a Fusion Brain with code in Visual Basic. I wrote a little demo application that shows exactly that, so people can copy the code into their own applications.
Screen shot:
Note: This application supports both the v3 and v4 Fusion Brains.
Compiled Application
Visual Basic Source Code (VB2008)
-Lance
mx270a is offline   Reply With Quote
Old 04-06-2008, 05:56 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Very nice!
Old 04-06-2008, 11:06 PM   #3
-zip-'s Avatar
-zip- is on a distinguished road
tyvm for this!
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 04-07-2008, 09:16 AM   #4
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
wow... rr plugin might be on the way since you laid an example out. I'm good with vb6 but never used VB2k8. We'll see how it goes lol.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 04-07-2008, 10:35 PM   #5
ginigma is an unknown quantity at this point
Excellent work. It's nice to have a third party tool to verify things are working.
ginigma is offline   Reply With Quote
Old 04-08-2008, 02:05 AM   #6
inh
inh is an unknown quantity at this point
sweeeeeeeeeeeeeeet!
Space Navigator - 6 Axis input device: Take it apart - Driver App
RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
inh is offline   Reply With Quote
Old 04-11-2008, 10:35 PM   #7
fjmf is an unknown quantity at this point
Thanks, I'll try to convert this over to a c# sample...
fjmf is offline   Reply With Quote
Old 04-11-2008, 11:28 PM   #8
mx270a's Avatar
New version is out. The screenshot and URLs in the first post point to the updated code.
I had one of the outputs labeled wrong, I added progress bars for the inputs, and I changed the inputs to show all 10 bits of data instead of only 8 bits.
-Lance
Old 04-12-2008, 12:05 AM   #9
2k1Toaster's Avatar
The main program is open source and already written in C#.
Old 04-22-2008, 12:43 PM   #10
mx270a's Avatar
This code has been updated to be compatible with the current FB firmware. The links in the original post go to the updated files. My old PIC was from late 2007, and some code had to be changed to get the new one to connect/disconnect correctly.
-Lance
Old 04-22-2008, 01:01 PM   #11
Terminal flasher
what time were the actual files updated.. i downloaded your source this morning and began working on converting it to an rr plugin. this was at about 11am eastern
03 Acura RSX Coupe
Old 04-22-2008, 01:07 PM   #12
mx270a's Avatar
Update was ~5 minutes before I posted the last message. Just check the version on the Form - I use the date as the version. If it's today's date, you have today's code.
2k1toaster and I have been discussing the send/receive stuff in the Disconnect sub. It shouldn't be necessary to Receive data there, but it's the only way I can get it to disconnect and reconnect nicely. Can you try remarking out the recieve if/then in the disconnect Sub to see if it will allow you to reconnect after you disconnect?
-Lance
Old 04-22-2008, 01:14 PM   #13
Terminal flasher
will do once i get the new source downloaded.. i gotta say thank you VERY much for releasing this open source as it has allowed a newb like me to understand how to communicate with the brain. If/when i release an rr plugin i will DEFINITELY be sure to credit you.
03 Acura RSX Coupe
Old 04-22-2008, 01:22 PM   #14
Terminal flasher
ok.. when i comment then if/then statement the FB will not reconnect. the only way i can re-establish a connection is if i close the program AND disconnect/reconnect usb. Now with the if/then uncommented it connects/disconnects/reconnects as it should.
03 Acura RSX Coupe
Old 04-22-2008, 01:23 PM   #15
2k1Toaster's Avatar
If you know how to make a COM object I would be forever greatful!
It just isnt working for me.
And I have not updated the source in a long time. I will package it all together and post it for you. That USB communication however has not changed at all.
Integrate fusion brain commands into road runner buttons scotty562 FB Software 15 09-22-2008 09:02 AM
power fusion brain from car battery customaudioman Fusion Brain 3 03-14-2008 07:41 PM
Skinning a custom VB application RJP350Z Software & Software Development 0 01-11-2005 09:36 AM
VB front end for SB Audigy control? wysocki Software & Software Development 2 12-14-2004 08:36 PM
VB Control for Character LCD's Jamez_Warner LCD/Display 0 05-17-2004 04:55 AM
