Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 04-19-2008, 05:19 PM   #1
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Fusion Brain MDX Software - MATH!
Wanted mathematical functions?
I am thinking sin/cos/tan and then a x^y type function... Perhaps a natural log?
I think the most useful would be the x^y because when making a Taylor Series, it can get tedious to do x*x*x*x*x*x*x*x*x*x*C type things.
Put up requests and I will think about it.
Again this is only for the MDX software, not Version 2.
Old 04-20-2008, 12:13 AM   #2
greenman100 is on a distinguished road
inverse sine, cosine, tangent, log base 10, natural log
integral, derivative
power
greenman100 is offline   Reply With Quote
Old 04-20-2008, 02:04 AM   #3
h3rk will become famous soon enough
absolute value, square root (although it may be redudant), and I like the ones above as well.
h3rk is offline   Reply With Quote
Old 04-20-2008, 02:25 AM   #4
In the world of controls, this one is kind of math:
how about delay on and delay off timers? I would be ok if the nemeric input to the timer was not seconds, but a multiplier to the timer object,
i.e.
my timer is at the default 50.
I want to create a root function that takes a temperature variable and compares it to a constant, if it is greater than the constant for 5 seconds. then do something (like set a boolean variable somewhere else to 1).
So, if 50 is 50ms, then 5000/50 is 100, so that would be the timer input I would use.
Then again, if you make it so that it to 5seconds, looked at the timer value and did that behind the scene, it would be more user friendly.
Time intervals may need to be defined for deriviative/integral as well.
Old 04-20-2008, 02:38 AM   #5
introduction of "time" to modules would also allow for filtering, and would allow for a possibly useful Totalizer (resetable).
Old 04-20-2008, 02:48 AM   #6
2k1Toaster's Avatar
You can actually access all history values of an analogue input anytime in the logic... Is that you meant? So you can get now (t=0) and t-1, t-2, t-3, t-4,... t-n where n is the number of history points an analogue input stores.
Integrate fusion brain commands into road runner buttons scotty562 FB Software 15 09-22-2008 09:02 AM
3-Day Midterm Madness Sale! Fusion Brain $20 2k1Toaster Fusion Brain 152 04-27-2008 05:30 PM
what the heck is a fusion brain? RadicalxEdward Newbie 18 04-06-2008 08:23 AM
few questions about hook up of fusion brain customaudioman Fusion Brain 37 01-17-2008 12:10 AM
Fusion Brain...Expansion? nsgrossman Hardware Development 4 01-02-2008 11:25 PM
