Hmmm...so if I understand correctly, to get digital output for things like the speedometer, I would just use a text label instead of multi-image? If so that sure is a lot easier than creating images of all the digits from zero-top speed.
The button definition screen shot is using 1280x1024. That was the only way I could see the whole window and as you can see, the bottom has input boxes and buttons chopped off.
Another thing I have noticed in the Configurator is that some sections remain in the area when you cancel or accept but others return to the main selection window. For example, going into the text label area and opening the definition of a label then clicking cancel, the editor stays in the text label selection window. Multi-images, however, return to the main selection window when cancel is clicked.
Its not a problem, just letting you know about the inconsistancy.
