Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 07-30-2008, 04:36 PM   #1
Grrrmachine's Avatar
Grrrmachine is on a distinguished road
Small errors
Nothing causing crashing or failures, just little mistakes (I think) I noticed whilst playing around with Uber MDX:
  • Logic statement form: Digital Output Node (blue lightning) is called Analogue Input Node
  • Error message on main page contains the word "Declrarations" (spelling!)
  • Function form and Logic form are both called CustomFunctionForm in the title - which is which? They look identical.
  • If you load something from the icon list manager and open its property, and then close it, the icon list manager goes all the way back to the root rather than just the last window you were viewing.
  • The right pane, in logic mode, bunches all the blocks together in a row so that the names become unreadable. When you go to Edit those logic statements, they're spread out as designed, but unreadable from the main window because all the names get garbled together.
Im not being picky, just little things Im noticing as I play around and thought you might like to know they're there.
Grrrmachine is offline   Reply With Quote
Old 07-30-2008, 05:29 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
1) Fixed
2) Fixed all 8 occurance. Stupid copy/paste
3) Fixed. Reason they are called the same is because they are the same page. I just hide and change the actions depending on which button you pressed to get there. Now it shows 2 titles.
4) Working on it...
5) You have to click save if you want the changes to be saved. The right pane makes an image from how you layed it out after you click save on the logic designer. So when you open up a skin with logic in it, it will all be bunched up because there is no position data in the file. The designer makes it up as it goes there. So when you move it all around in the logic editor, click save and it will be saved in that state and the right pane will show it like that. But once you do a full save of the skin, and reopen it, all that positioning is lost, because again the skin file does not contain any location data for the modules because it works completely differently inthe main program. That is why all functions you make have both the xml file which the main program needs, and a *.designer file which contains gibberish location data.
Keep pointing things out, as I wouldnt have caught them for a while.
7" screen just 2 small corsamel General Hardware Discussion 16 10-07-2004 07:45 AM
looking for a 5.1 channel SMALL amplifier RogerWilco General Hardware Discussion 3 09-21-2004 04:19 PM
Routis 2004 buttons are too small on a 7" widescreen WhiteRabbit GPS 11 07-24-2004 11:12 AM
highout, small capacity battery? jshrieve Power Supplies 7 06-15-2001 04:34 AM
small power supplys Aladdin General Hardware Discussion 1 02-26-2000 10:19 PM
