Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 08-23-2008, 05:54 PM   #1
dhantiflag's Avatar
dhantiflag is an unknown quantity at this point
FCC freezing... blank config
so i have fcc installed in my carpc and a desktop in my house...
no mater what i do.. after hibernation or randomly sometimes... it freezes...
i have no controls or anything in the config so im not sure what could be causing this....
dhantiflag is offline   Reply With Quote
Old 08-23-2008, 06:13 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Could be having to do with DirectX. Is this the latest version?
Have you tried running it in basic video mode? Do you get a message when it dies or just the "program has stopped" blanket message?
Old 08-24-2008, 12:24 PM   #3
dhantiflag's Avatar
its just program has stopped, i tried in basic too and it seemed to do it...
its on 2 complete diff machines too :-/
Old 08-27-2008, 04:02 PM   #4
dhantiflag's Avatar
still got probs on both computers, complete diff setups....
always freezes after hibernate too
Old 08-27-2008, 04:17 PM   #5
greenman100 is on a distinguished road
more info on issue:
dhantiflag1: its weird tho, its not like completely frozen, i can make it max then i can see ****, but u cant click buttons or what not
greenman100 is offline   Reply With Quote
Old 08-27-2008, 04:18 PM   #6
dhantiflag's Avatar
and it freezes with no brain connected*
Old 08-27-2008, 04:22 PM   #7
dhantiflag's Avatar
Old 08-27-2008, 04:25 PM   #8
dhantiflag's Avatar
1 more weird issue* sorry to post so much...
after i get the screenshot above... sometimes not always i can resize it and it comes back.
Old 08-27-2008, 04:32 PM   #9
2k1Toaster's Avatar
Make a button on the page to change to a different page. Then try.
If MDX is really frozen, it would not maximize or minimize or anything. And further if the change to a different page works, then it is hardware or driver related. I have put the program in hibernate, standby, even clicking things while entering standby/hibernate, and every time it comes right back to life.
It is hard for me to fix something I cant even diagnose as a problem.
Also run with the "-debug" command line switch. If there is an error, and it is freezing, an error message will popup and the program will tell the problem. I need that error if shows up. If it doesnt, then I know the program itself is ok. I am guessing it is either hardware or driver.
Usually when I do testing I do it without the Brain hooked up. One of the reasons is it is a laptop and I program everywhere, usually not at a place where I plug in and test. Reason the virtual brain was born.
Old 08-28-2008, 10:27 PM   #10
2k1Toaster's Avatar
Try the new update. I have removed all ACPI event handlers, and program closing handlers. So now it will just go blindly until closed.
Old 12-04-2008, 05:16 PM   #11
bratnetwork's Avatar
bratnetwork is an unknown quantity at this point
I know this thread is a little old, but I'm having problems with hibernation also... The brain itself is fine after hibernation, its the program that I'm having problems with.
After it comes out of hibernation the program is transparent and you cant even click around to try to hit a button. But if i make it re-sizable then if i just grab the edge and resize it, then the graphics pop back and everything is good. The problem is that when its embedded into roadrunner i cant do this.
When you come out of hibernation and the problem occurs the brain still works - I set it so one of the inputs would trigger an output and even when the program is messed up I can trigger that output so it seems to me its just a graphics issue.
I had this issue before but ignored it hoping it was something stupid, then I got a SSD drive and did a fresh install of windows and fusion and i still have the problem. Also happens on my dell laptop.
Debug mode does not give me any messages.
I'm running Intel DG45FC Mini-ITX Board, Intel E4500 Core2Duo Processor, with Windows XP Pro SP2...
Where do I begin to troubleshoot this?
bratnetwork is offline   Reply With Quote
Old 12-04-2008, 05:42 PM   #12
dhantiflag's Avatar
heh, no idea I STILL Have this issue... exactly the way u described it...
bump bump bump for nick
Old 12-04-2008, 05:45 PM   #13
there has to be something in common with our setups... it must not be happening to many others because no one else has brought up the topic really other than us... or they just aren't hibernating...
Old 12-04-2008, 05:50 PM   #14
dhantiflag's Avatar
i got EVGA mobo, core2duo, xp sp2
Old 12-04-2008, 06:04 PM   #15
is your XP modified at all or shrunk? I took a few features out of mine, but that why i tried it on my laptop too bc that has a full version.
Lilliput 619 Blank Sreen?? HELP Shmeker LCD/Display 11 11-28-2007 11:54 PM
RR install and config PDF accentsound Road Runner 2 08-21-2005 08:27 PM
Questions about RR config Enforcer Road Runner 8 07-21-2005 12:48 PM
Store keypress config? and remote config troubles. lilmansplace Media Engine 1 04-08-2005 06:07 PM
