Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 09-05-2008, 01:49 AM   #1
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Fusion Control Centre - New Built In Function - "Between"
There is a new function in MDX and the Configurator. Between
This will cut code from needing 3 modules to only needing 1 to do the same thing. It is built into MDX and the Configurator now so the function parsing will take less time each cycle saving CPU. Logic such as steering wheel button control and other comparative functions will benefit greatly from these.
They will be released in the next public version.
In the first image from top to bottom of the modules shown, are Between II, Between EE, Between EI, and Between EE. "I" stands for Inclusive and "E" stands for Exclusive. Inclusive is the "or equal to" part of "greater than or equal to" and "less than or equal to".
You will notice 4 nodes on this module. In the expression a < b < c, the Top node is "a", bottom node is "c" and the middle left is "b". The node on the right is as usual the output node.
Second image is just an example of it being used as a test which should always be true unless integer math changes somehow.
*NEW* USB Input/Output Board -- Fusion Brain 2k1Toaster Fusion Brain 1122 11-07-2009 12:21 AM
vb.net code for volume control takissd Software & Software Development 17 12-27-2008 05:19 PM
Need wiring help for 2005 Grand Prix. derekmac Car Audio 33 09-21-2007 10:42 PM
Remote with built in mouse control spaceman Input Devices 2 05-25-2005 02:09 PM
My hardware/Software computer control system - Wish list/feedback - Easy power off DarkWolf General Hardware Discussion 22 08-13-2001 02:42 PM
