Quote: Originally Posted by
sv1cox
1. every time i close the skin window and reopen it FB is not there. I have to close it again, unplug the usb and plug it again. Then if i open the skin again everything is ok (FB is present and working).
Panos
2k1Toaster
1) h3rk mentioned this too. Areyou by chance using an AMD processor or HP computer?
sv1cox
hi agn
i am not near that laptop now but no it's not a HP it is a cheap Fujitsu Siemens, i am almost sure its on Intel.
as for drivers, yes i unistall and delete all the old drivers and then rebbot but, i have to mention that, before install the new ones i could see in Device Manager a direcory "Other Devices" with a Fusion Brain inside, u can remove it but not "delete drivers". So i unplug the FB and it go away.
It is like when you close the skin you also close the USB link with the FB.
As for the buttons the sad thing is that i dont need toggle buttons. The oposite is the problem. I can not make a stable ON/OFF button. I will play with the wizard tommorow in case i did something wrong.
thanks, Panos.
I'm not crazy!!!
I've tried it over and over and it still loses communication on my laptop. The drivers seem ok in Devmgr but the software wont talk to the brain after running, closing, and restarting MDX. I did eventually get it to work on my carpc, but I had to be unusually persistant with unistalling previous drivers.
I have two or three more PCs to try this on, but I'm still in the process of moving, so I'll do more trials with this problem when I can (next week, probably).
I am available for testing any possible fixes or troubleshooting on my laptop, if reproducing the issue isn't possible.
