Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 11-05-2008, 02:12 PM   #1
JiC
JiC is an unknown quantity at this point
Question MDX Configurator question (connecting nodes)
Hey all. Sorry to make this my first post (I was hoping that would be a full write up of my install and introduction) but I've hit one silly snag with the FB.
When placing nodes/operators on the Block Builder Form how do you acutally connect the nodes? Looking at the example configuration they are connected by red lines ... how the heck do I get add those!?
Thanks for reading and thanks in advance to whoever clues me in ..
- Chris
05 Altima 3.5 5 speed
RR + DigitalFX
JiC is offline   Reply With Quote
Advertisement Sponsored links
Old 11-05-2008, 02:24 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Definitions that make it easier:
Module: The block, main image, picture describing what it does
Node: The little circles on sticks protruding out of the module
Link: The actual line between the 2 modules connected between an output node and an input node on seperate modules
Answer:
So to connect, right click a node to begin with, then left click another node to end it. You can only connect output nodes of modules to input nodes on other modules. Loop-backs are not permitted. Both of these will show an error if it happens and prevent the linking.
So right click output node of module A, then left click input node of module B.
Old 11-05-2008, 02:27 PM   #3
2k1Toaster's Avatar
Also as an FYI, your posts are moderated since you just registered. So after you post a message, Tim or I must approve it before it is shown. I saw you made 2 threads (both moderated). So I approved this one, and deleted the other one. So dont go crazy when it doesnt appear right away, you have to wait until one of us sees it and lets it through (until you get above the post threshold)
Old 11-05-2008, 02:56 PM   #4
JiC
Awesome, thanks for the quick response and a really cool product!
I made the mistake of fabbing up the entire carpc inside the actual car before getting to work on the FB so I've been using the touchscreen for all of the mouse work and it didn't occur to me to try that.
Also sorry about the double post, After posting the first one I closed the tab without even seeing the confirmation screen, after not seeing the post come up I made another post and then READ the confirmation screen saying posts were moderated.
Old 11-06-2008, 12:19 AM   #5
2k1Toaster's Avatar
You can build your configuration file on any PC, and move it whereever you want. So you can develope the file inside, then just transfer it outside.
You can even use the virtual brains to simulate a FB in software so you can see what is going on without needing to plug one in.
Old 11-15-2008, 10:48 PM   #6
UniqelyCommon's Avatar
UniqelyCommon is an unknown quantity at this point
*whew* finally found this!
AHHH! THAT's how its done! Might I ask why both left and right mouse buttons are used? This seems like an unintuitive requirement to me (for whatever that's worth ) that could be simplified to just the right button (or just the left). What was frustrating, though, was after clicking and dragging with the right button, getting an error message (don't start from an input) , trying it in reverse (outs to ins) with the right mouse button, and getting NOTHING. I was wondering if the lines weren't being rendered (due to a non-refresh, hardware issue, etc.).
ANYWAYS...thanks for such a great product (both hardware and software). With such great software with so many features, its hard to get every single quirk perfected!
UniqelyCommon is offline   Reply With Quote
Old 11-16-2008, 01:58 AM   #7
Dougw133 is an unknown quantity at this point
Same here! Struggled for an hour trying to figure out how to connect the nodes..The "?" buttons dont contain help and I couldn't find this anywhere...
Dougw133 is offline   Reply With Quote
MDX and COM big update 2k1Toaster FB Software 61 05-04-2009 11:04 PM
Fusion Brain Latest Software MDX - Download Link 2k1Toaster FB Software 32 02-21-2009 12:05 AM
How to use a configuration file created by the Configurator with MDX 2k1Toaster FB Documentation and Tutorials 15 09-08-2008 05:36 PM
Quick overview of the Fusion Control Centre MDX Configurator 2k1Toaster FB Documentation and Tutorials 0 06-06-2008 06:17 AM
Logic question - MDX - placing nodes correctly? h3rk FB Software 2 04-17-2008 04:04 AM
