Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 11-06-2008, 12:41 AM   #1
flyingmonkey350 is an unknown quantity at this point
Time triggered events
Is there a way to get fusion brain to check the computer time and trigger an event? Say At 8am trigger output 1 etc.
flyingmonkey350 is offline   Reply With Quote
Old 11-09-2008, 12:57 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Currently no. Time is relative in MDX. I can add it without too much problem though.
So you want to be able to base if/then logical statements off of the current time correct? Easy enough. I will add it to the list of to-dos.
Old 01-03-2009, 10:24 PM   #3
bdlitzer is an unknown quantity at this point
Time based Logic
I am surprised this does not have this feature. There are many many uses for time based automation. Many things just need to be done at a certain time that are not based on specific environmental conditions.
Another thing - can their be a random feature for the the ole' turn on the lights at a different time every night and other situations where some randomness is desired?
Please do add time based logic/processing capabilities
Thanks,
bdlitzer is offline   Reply With Quote
Old 01-05-2009, 01:22 PM   #4
2k1Toaster's Avatar
Thanks,
I am adding Time. I will also add a random feature.
I will be out this week though so it wont be until next week anything is updated.
Old 01-07-2009, 04:37 PM   #5
GadgetBandit's Avatar
GadgetBandit is an unknown quantity at this point
Thank you!
GadgetBandit
GadgetBandit is offline   Reply With Quote
Old 01-20-2009, 01:45 PM   #6
and when you incorporate time, could you post a piece of example code for us idiots?
Thanks,
GadgetBandit
Old 01-28-2009, 11:48 AM   #7
I'm almost done wiring my hydroponic project.
button - on/off
input0 - full switch
ouput0 - pump
output1 - drain value
I need help. Books on XML haven't provided much except working with databases and the web. I need examples for looping and branching . . . and time. I'm monitoring light, temp, and humidity. I can turn on/off irrigaton, manually, but need values to go off automatically after 5 minutes or so.
The hydronics is a stretch. I need to fill a tray, wait ~10 minutes, drain for 15 and repeat. This seems overwhelming and could really use help.
Thanks,
GadgetBandit
Old 01-28-2009, 12:07 PM   #8
2k1Toaster's Avatar
Just a heads up, xml has nothing to do with the data encoding that MDX reads. XML is just the file format that MDX uses, nothing more nothing less.
All the instructions are parsed out by MDX and interpretted by MDX. If you open the XML file in a web browser, it will just display the text of it since XML itself is just the format containing text, not a format containing programmatic instructions.
The way MDX works is based on logic sections. So if you want to branch somewhere, you have a variable that gets set to some value based on some logic block. So your conditional statement then in the then-do section you change a variable to some value. Then in another logic block you do a conditional based off of that variable's value. Usually you dont need to branch though so I dont know what you need it for.
As for looping that is easy but same principle. 1 variable increments every logic block. Then a block that does "if variable is greater than loop_max then reset variable to idle state or back to beginning" depending on if you want a loop finite or infinite. Then in a logic block you do "if variable is between x and y then do whatever" which is the inside part of the loop.
Time is coming, I have been distracted lately with other side projects and uni. I am still trying to lay out a good foundation for the time triggered events. Such as when and how often. Say every hour, or every tuesday, or every 4th of the month, or every second millenia or something like that. I think what I came up with will work, it will just take some time coding in.
Old 02-26-2009, 12:35 PM   #9
2k1Toaster's Avatar
Here is the beginning:
Old 04-08-2009, 10:45 PM   #10
What is a realistic timeframe?
Thanks,
GadgetBandit
Old 04-08-2009, 10:48 PM   #11
2k1Toaster's Avatar
It is already in MDX. Not in the configurator. Probably wont be for a while.
But it is fully functional as far as I remember in MDX as of the late Feb. update.
Old 04-09-2009, 02:28 PM   #12
The last post in feb said "here is a beginning."
How do I get to it? Have I missed a thread that discusses it?
GadgetBandit
Old 04-14-2009, 07:46 PM   #13
It ain't a car. But the brain monitors my greenhouse and drives the hydroponics. It's a pain to run logic at 100 and try to count seconds. "Time" is important for 24 hour cycles. Please.
GadgetBandit
Old 04-15-2009, 12:03 AM   #14
2k1Toaster's Avatar
Sorry I missed replying, thought I had. Things have been hectic.
But it is in the current release, pretty sure it came just after I posted that post with the pic.
Here is the code:
Code:
/* <task id="Task Test" minimum_delta_vote_time="1000"> <when year="XXXX" month="XX" day="01" hour="XX" minute="00" second="00" /> </task> <task id="Task Test 2" minimum_delta_vote_time="1000"> <when year="XXXX" month="XX" day="Thursday" hour="XX" minute="XX" second="00" /> </task> */
Old 04-15-2009, 12:06 AM   #15
2k1Toaster's Avatar
XX means dont care.
And day can be a day of the week as a string or a number.
Also numbers can have "X" in the spot anywhere in the number. So you could make the minute "X0" for it to fire every 10 minute tick and so on.
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
Feature request: Show the total track time, not just the elapsed time johnk StreetDeck 8 06-02-2007 09:49 AM
who cares about the date and time? (POLL) liquid_smoke Road Runner 26 08-10-2005 09:34 AM
Looks like the time has come to find another frontend TucsonPred Media Engine 4 08-01-2005 03:52 PM
